rik arry | 11/06/2023 21:11:02 |
56 forum posts 3 photos | Hi looking for advice , I’ve a late Myford S7 95ish imperial with gearbox . Thanks in advance Edited By rik arry on 11/06/2023 21:33:28 |
Nigel Graham 2 | 11/06/2023 21:41:55 |
3293 forum posts 112 photos | Could you think it the other way round? If most of your threads will be metric then the gearing for metric screw-cutting becomes your default so stays there most of the time. Then the "temporary" changes are for the occasional inch-based threads. The use of "temporary" in the manual probably assumes as it is an Imperial-dimensioned lathe and most were probably sold in the UK, most users will cut mainly inch-based threads anyway.
Hopper | 12/06/2023 03:28:38 |
![]() 7881 forum posts 397 photos | I cant see any reason you could not leave it on there permanently if metric is your main use. |
JohnF | 12/06/2023 07:53:41 |
![]() 1243 forum posts 202 photos | Rik, Nigel's analysis is correct but look at this thread which is a simple way to cut metric and although there are pitch errors they are so small for most jobs they are good enough. If you really need to be 100% accurate then you can always use the metric kit you have along with the necessary change wheels. https://www.model-engineer.co.uk/forums/postings.asp?th=125630 John |
Martin Connelly | 12/06/2023 08:08:45 |
![]() 2549 forum posts 235 photos | I expect the "temporary" description is due to the fact that the thread dial is redundant on an inch based leadscrew being used to cut metric threads. It would be expected that you would not want to leave it in that state if you were cutting a lot of threads. However for a non-industry user the extra time taken of having to leave the half nuts engaged and reversing the drive is not going to have a cost. Additionally, if you cannot reverse the motor on the lathe then you will need to hand wind the spindle backwards for each pass. Doing a lot of metric threads would soon become tiresome. There is also the slight risk of a screw on chuck unwinding, not a problem if using in the spindle collets. Martin C |
not done it yet | 12/06/2023 09:34:18 |
7517 forum posts 20 photos | Agree entirely with Martin. I’ve yet to come across a lathe that could not be wired for both forward and reverse rotation, but I expect there are a few tinier lathes in this category. Using a cutter holder which ‘skips’ on the return direction would help considerably if doing a lot of threading that way. I have one, but never used it. |
SillyOldDuffer | 12/06/2023 11:25:22 |
10668 forum posts 2415 photos | The 'temporary' note made sense when the Myford S7 appeared, and for decades after. In 1952 UK production was dominated by Imperial measure, with Metric available as an option. British industry, foolishly in my opinion, resisted metric, and home workshops were even more conservative. Even today there are Brits who believe Whitworth is the best of all possible screw-threads, All change! 70 years later, apart from the USA and legacy production, most world manufacturing is metric. Almost all new design is metric. Today Imperial is more likely to be only needed on special occasions, and it's become 'temporary' on most machines. Model Engineering may be the exception because classic British steam locomotives plans are invariably imperial. In a workshop dedicated to building them, not much call for metric, so it's still 'temporary'. The only objection to metric being mounted permanently on an Imperial only lathe I can think of is if the conversion needs a permanently mounted 127 toothed gear. They're inconvenient because they take up so much space on the banjo. Dave |
DC31k | 12/06/2023 15:25:00 |
1186 forum posts 11 photos | When the metric conversion set is fitted, you lose the fine feed capability of the lathe. Please see Brian Wood's reply in this thread: https://www.model-engineer.co.uk/forums/postings.asp?th=133063 Please also see this document: https://www.haythornthwaite.com/Myford%20Metric%20Conversion.pdf If you only ever want to cut threads with the lathe, make it permanent; if you want to retain sliding or surfacing auto-feeds, it has to be temporary. |
