Neil Greenaway | 08/05/2023 22:42:48 |
75 forum posts 3 photos | Hi, Would anybody know if what was recommended for lubrication on the high/low and feed gearboxes in a Herbert type v drill? I have one which has been "repainted" at some stage I'd say about 40 years ago and some fixings overpainted so I'm not sure there are fill/drain plugs on the main gearbox (probably about 70year old?). The feed gearbox has spring lid oil cups so I'd reckon this is a total loss type which leaks whatever you drop in. Its a smashing machine, and runs very smooth and quiet with loads of torque. I'm aiming to look after it and hopefully it would run maybe another 70 years. Thanks Neil |
Emgee | 08/05/2023 23:23:59 |
2610 forum posts 312 photos | I used grease in the quill downfeed via the nipple provided, the table feed box was removed as some gears were missing, never did replace them but used it manually. Emgee |
