Kevin Murrell | 17/04/2023 18:58:26 |
59 forum posts 6 photos | Hi all I need to move my WM14 mill in the back of my car. I dont have the space to build a frame or some other support. Even with the head right down it's quite top-heavy. Can I remove the head complete with motor? (Something is stopping it, but I haven't looked properly yet.). Will I get it back on afterwards? Kevin
Stuart Smith 5 | 17/04/2023 20:16:37 |
349 forum posts 61 photos | Kevin I have a Warco WM16 mill which looks to be a similar design. I bought it secondhand and it was in a first floor workshop with access via a narrow staircase. I split it into 3 parts to move it. I removed the head in one complete part with just 3 nuts/bolts to remove. I watched this video on you tube to see how to do it. He went over the top making a block to hold it. I just lowered mine onto a block of wood on the table. **LINK** Then I removed the table just leaving the base and column together. I removed the complete x/ y table by winding it forwards. I had to remove the lead screw nut from under the table . It was held in place by 2 screws, accessed from the back. This is the heaviest part but one person can lift it though best with 2. (My son in law moved it from my car to my workshop on his own before I had chance to help!) Myself and previous owner carried the parts down the stairs between us without any problems. So you should have no trouble doing the same. You can download a manual from the US site of Grizzly tools which looks like a similar design. **LINK** Stuart |
not done it yet | 17/04/2023 21:19:43 |
7517 forum posts 20 photos | How much does it weigh? Appears to be only 60kg? I might remove the table, but basically carefully lay it down, secure it to a sensible plank and shift it with one person at each end. |
