Solder resist
John Haine17/04/2023 09:32:13
5563 forum posts
322 photos
Not really an electronics question but related. I'm trying to refine my technique for making pendulum suspension springs. Basically these are a strip of beryllium copper about 16mm wide which have thick brass "chops" soldered on each side of each end for mounting. The active length of the spring in between the chops is a few mm. The soldering problem is to prevent solder squeezing out from the chops when molten and forming littlee blobs on the active surface that could affect the uniformity of the bending. So I would like to put something on the spring surface between the chops that will inhibit solder wetting. This is the same sort of requirement as a "solder resist" on a PCB except that I will want to remove it after soldering.
Does anyone have any ideas for what I could use please? I've seen Tippex mentioned I think, I'm not even sure if that's still made! Soldering by the way is using electronic silver solder, either cored wire or paste.
bernard towers17/04/2023 10:40:17
1221 forum posts
161 photos
tippex every time, make sure you use the red logo bottle not the green. when finished wash off with cellulose thinners or gun wash
John Haine17/04/2023 11:29:46
5563 forum posts
322 photos
Thanks Bernard - does it still wash off after heating or does it need scraping?
Steve Skelton 117/04/2023 16:15:01
152 forum posts
6 photos
Jewelers rouge mixed in a little water and painted onto the surface you do not want the solder to be on has worked great for me - no issues with solvent or going off over time. Is removed easily afterward.
bernard towers17/04/2023 19:33:58
1221 forum posts
161 photos
Washes off after soldering
John Haine17/04/2023 21:47:50
5563 forum posts
322 photos
Thanks for the input everyone. Actually I have a little pot of rouge somewhere, I'll give that a whirl first if I can find it. Tesco seem to have Tippex so I'll try that if the rouge doesn't work.
Martin Kyte18/04/2023 07:40:22
3445 forum posts
62 photos
Why are you not riveting the chops to the spring?
regards Martin
John Haine18/04/2023 12:02:08
5563 forum posts
322 photos
Posted by Martin Kyte on 18/04/2023 07:40:22:
regards Martin
Well, I have decades of experience with soldering and none of riveting! But Matthys recommends soldering to ensure that the edge of the chop is firmly in contact with the spring. There's some evidence that if there's a small gap then the CD of the pendulum can be unpredictable as the bend brings the spring into contact. I've also just recently replaced the spring on my new pendulum with one that has a wide single leaf rather than a double, and I took more care with soldering, and it looks like this on its own has significantly reduced the measurement noise I was seeing.
John Haine18/04/2023 14:58:40
5563 forum posts
322 photos
...and it has also increased the pendulum Q by 60%!
Martin Kyte18/04/2023 16:21:43
3445 forum posts
62 photos
Sounds reasonable John. Thanks for the explanation.
regards Martin
