Myford lathe power cross feed
john fletcher 112/04/2023 15:23:04
893 forum posts
Is the thread the same on power cross feed lead screw on a Myford Super 7 lathes, on both a Metric and and Imperial lathes. Alternatively will the same lead screw fit either Metric or Imp ? John
bernard towers12/04/2023 15:48:26
1221 forum posts
161 photos
crosswise screws are 10 tpi for imp and 2mm pitch for metric and I think you will find that the lead screws are all imp.
John Haine12/04/2023 15:55:45
5563 forum posts
322 photos
AFAIK the only difference between imperial and metric S7 is the crossslide and topslide screw pitches. which as Bernard says are both 2mm pitch. The Xfeed dial is marked in mm off diameter however, i.e. t turn is 4mm. The leadscrew is 8 tpi in both but (un)helpfully the handwheel is calibrated in metric! i.e. 3.175mm full turn.
Edited By John Haine on 12/04/2023 15:57:22
john fletcher 113/04/2023 11:46:19
893 forum posts
Thank you both Bernard and John, worth knowing, its to help a friend. John
