JasonB | 25/03/2023 18:35:37 |
![]() 25215 forum posts 3105 photos 1 articles | Or more precisely a replica of the Stuart Models "Progress SH" |
Ches Green UK | 26/03/2023 18:29:53 |
181 forum posts 7 photos | Jason, I see you use a version of Alibre. The results always look very good. And it's great to see the old Stuart models being 'reborn'. One day I'd like to acquire some CAD/CAM s/w, objective being to eventually use it on a (also to be acquired) 3D printer. Do 3D printers require G code or does (whatever version of ) Alibre come with everything one would need? Thanks, Ches. PS: Sorry if this is slightly off topic. |
David Jupp | 26/03/2023 18:57:39 |
978 forum posts 26 photos | Ches, All levels of Alibre software can export designs as STL (which is the starting point for 3D printing). 'Slicer' software processes the STL file into g-code to drive the 3D printer. There are generic slicer packages and ones tied to specific printer brands - you can pay for slicer software, but there are very competent free options. |
Ches Green UK | 26/03/2023 19:07:23 |
181 forum posts 7 photos | Jason, |
JasonB | 27/03/2023 07:14:22 |
![]() 25215 forum posts 3105 photos 1 articles | Could not have put it better myself. As an example the question of a missing pulley casting came up on MEM forum last week, someone dropped me in it saying I could CNC a pattern. I saw the post and within a few mins had put up an image of the pulley. Turns out the person has a 3D printer so a couple of mins more work adding machining allowance and draft angles and The pattern was ready to export as both STL and STP files which I e-mailed to him. He was printing within half an hour having processed the file through Prusa's own slicer software. Also last week I sent someone else a complete assembly of a Stuart Victoria, waiting to see how that comes out printed with a Resin Printer |
Gary Wooding | 27/03/2023 09:25:41 |
1074 forum posts 290 photos | Posted by JasonB on 25/03/2023 18:35:37:
Why do you model in Alibre and export to F360 for CAM? Why not do the modelling in F360 too? |
Ches Green UK | 27/03/2023 09:38:18 |
181 forum posts 7 photos | David, My apologies. I had assumed it was Jason that had so quickly responded. Anyway, thanks to you both. It does seem a very potent design/manufacturing prodecure, certainly for small batch production. Am I correct in thinking that if one didn't have a 3D printer or CNC machine, then Alibre could just as quickly 'draw up' dimensioned drawings of the Pulley and electronically send them to an iPad next to the manual mill or lathe? I was trained to BS308 so have a reasonable understanding of drafting. But alas, missed out on the next-gen revolution ie CAD ....by then I had moved in to the engineer ranks where we sketched out our ideas and passed them to the CAD DO. OK, well I'm away to think about it all. All the best, Ches Edited By Ches Green UK on 27/03/2023 09:40:04 |
David Jupp | 27/03/2023 09:58:36 |
978 forum posts 26 photos | Ches, As with almost all 3D CAD packages - once you've produced the 3D model, generating traditional 2D projected views in a drawing and adding dimensions is simple. You just have to decide which views you want to include, add dimensions as desired, the dimension values are derived automatically from the 3D model (and will update if you edit the model). The finished drawing can be published as a PDF, which is probably simplest way to share it to another device. |
Ches Green UK | 27/03/2023 10:06:19 |
181 forum posts 7 photos | David, Got it, thanks. I've have a number of projects on my plate at the moment but I guess it wouldn't hurt to get a copy of Alibre Atom 3D, even if only for the 30 day trial. Ches |
David Jupp | 27/03/2023 10:17:44 |
978 forum posts 26 photos | The 30 day trial is a great way to check out the software - make sure to get the Atom3D trial if that is the product level you are interested in, as the Alibre Design trial includes extra capabilities that you'll miss if you later switch to Atom3D. The Atom3D interface is simpler too, so quicker to learn. There is Atom3D specific training material available here There is also an active user forum. If you get stuck during the trial, rather than waste time, reach out to the reseller or to Alibre support for help. There's also the built in Help. Be aware there is a mindset shift from 2D to 3D - some really struggle to make the change, for others working in 3D is actually more intuitive. |
JasonB | 27/03/2023 10:24:57 |
![]() 25215 forum posts 3105 photos 1 articles | Gary, having used Alibre for over 10 years I have a lot of files that I do still go back to and I'm also quite happy and conversant with Alibre so don't really want to go with something else. F360 in it's non commercial form is fine for the small amount of CAM that I use it for and as I also tend to use Alibre for my work as well as using DXF and DWG output for hobby use it would mean having to pay for F360 too. At the moment I opt for the yearly maintenance for Alibre Professional and that is less than the more expensive yearly F360 licence would not really be worth paying for both. I will do the odd tweak of an imported STP file in F360 such as filling in a hole so the CNC does not try to machine it out or as I have done on this bed part model the shape of the stock. Ches, as David says I find a pdf output the best way to share my drawings with others and they also go to our editors for publication in the mag. This will give you an idea of the output. Though for my own use I tend to just pull the dimensions off the 3D model and sketch them out onto a scrap of paper in most cases. |
Ches Green UK | 27/03/2023 10:35:55 |
181 forum posts 7 photos | Jason/David, I'm conscious that I've hijacked Jason's 'Progress SH' build thread with my CAD/CAM Qs, so I'll quietly step back Nonetheless, the info you've both given me has been very useful. As has seeing how it all applies to the real-world use on the Progress SH. Alibre 3D, the cost-effective option, is very likely the one I'll go for when I do make the plunge. Ches. Edited By Ches Green UK on 27/03/2023 10:45:39 |
JasonB | 29/03/2023 19:37:57 |
![]() 25215 forum posts 3105 photos 1 articles | The main bearings started life as two pieces of bronze that were milled to overall size before being drilled and reamed 5mm |
JasonB | 01/04/2023 19:37:21 |
![]() 25215 forum posts 3105 photos 1 articles | The cylinder started life as a piece of 40mm cast iron bar that was faced and cleaned up on it's OD before turning around in the 3-jaw to face the other end to the finished 28mm length before drilling, boring and then reaming 12mm. |
Neil Lickfold | 02/04/2023 00:26:46 |
1025 forum posts 204 photos | One of the tings I use alot , is sacrificial softjaws on the vice. You can create pockets or cut a relief to be like a parallel but with an inbuilt stop etc. Very nice thread and showing how you use both cnc and manual tools to make a really exciting project. A great thread to follow. Thank you very much.
Ches Green UK | 02/04/2023 09:39:51 |
181 forum posts 7 photos | Very nice thread and showing how you use both cnc and manual tools to make a really exciting project. Yes, agreed. I like how Jason shows the CAD drawings and then how he turns those into actual parts. Ches
JasonB | 07/04/2023 19:51:20 |
![]() 25215 forum posts 3105 photos 1 articles | Thanks for the comments I'm not keen on the "+" shaped reinforcing ribs that Stuarts used on the valve chest cover as they look out of place on a small freelance engine and are not done that well anyway so I opted for an elliptical recess to tie in with the shape of the glands and to keep things similar also turned a round recess in the cylinder end cover rather than the conical protruding one Stuarts used. I did not take any pictures of the various rods, pins and guide rails as they are all fairly straight forward turning jobs so next post we will see what I looks like with a lick of paint. |
Martin Connelly | 08/04/2023 08:02:03 |
![]() 2549 forum posts 235 photos | Neil, I use chuck soft jaws frequently and see Jason has also used them in this build which I feel should be mentioned as well. They are good for ensuring parts are mounted concentric for second operations and also with the machined faces in the correct plane without a lot of checking, adjusting and repeating. They are also good for firm holding without marking the gripped surface. They really save time when there is more than one part with the same diameter to be gripped for second operations. Jason, I am curious about the soft jaws in the chuck used for milling the ellipses. Were they milled to suit in the mill or just left as they were from when they were on the lathe? Martin C |
JasonB | 08/04/2023 10:10:05 |
![]() 25215 forum posts 3105 photos 1 articles | Martin. that is my old lathe chuck that does not get used much on the lathe now and the jaws were done in the lathe. On both the lathe and mill I tend to use them more for the fact they provide a backstop for shallow work rather than for concentricity and in this case just clocked the part in with a dti in the spindle This set of jaws have only been machined for approx 35 and 60mm diameters by just over 1mm deep for each and I use them the most as they will hold anything from 25 to 75mm dia quite firmly if you don't go too mad with DOC
JasonB | 10/04/2023 16:46:36 |
![]() 25215 forum posts 3105 photos 1 articles | I decided to use the same Forrest Green and satin black colour combination that I have used for the other Stuart Replicas which did not take long to apply as there are not that many parts and what's there is all quite small |
