Graham Meek | 18/03/2023 11:04:30 |
714 forum posts 414 photos | I was wondering if there are any Unimat SL users on the Forum. I am making a tailstock support for my Proxxon/Emco Dividing Attachment set-up. I was hoping to use the same size centre mounting diameter at the Unimat SL, which I think was 7mm or slightly over. Can someone confirm this size for me?
Regards Gray, Edited By Graham Meek on 18/03/2023 11:05:29 |
Thor 🇳🇴 | 18/03/2023 11:11:45 |
![]() 1766 forum posts 46 photos | Hi Gray, Mine is 7.15mm measured with a cheap digital caliper. Thor |
Tim Hammond | 18/03/2023 11:24:04 |
89 forum posts | I've just measured my dead centre using a M&W micrometer and got a reading of 7.18 mm.dia. The shank on my revolving centre measured 7.19 mm. HTH. |
Andy Carlson | 18/03/2023 11:29:31 |
440 forum posts 132 photos | 282.6 thou on my Imperial mike... which is 7.18mm. Mine are a pretty easy sliding fit inside the head/tailstock bores. |
Hollowpoint | 18/03/2023 14:53:16 |
550 forum posts 77 photos | Just tested mine, they tally with everyone else's measurements. I have 2 unused dead centres, the shanks are 7.185mm and the shank on a as new revolving centre 7.190mm. Measured with a M&W micrometer which I know is very accurate. 🙂 |
Graham Meek | 18/03/2023 15:18:03 |
714 forum posts 414 photos | Thank you all for responding to my request, I had the figure of 7.2 mm stuck in my mind, but it always pays to check. Regards Gray, |
