Tony Martins | 08/03/2023 11:32:04 |
2 forum posts | Good morning all I have a need to machine a length of 1.5" dia x 1" TPI straight cut thread, my 1800 Student lathe is not man enough therefore I dreamed I may be able to use my indexing head on the mill and mill a spiral thread but as my indexing head is not a universal head I would like to know if it can easily be converted in some way to manually power the mill table by using a timing belt type drive or should I go back to sleep again. Any ideas will be much appreciated. Regards Tony ABM |
JasonB | 08/03/2023 11:37:22 |
![]() 25215 forum posts 3105 photos 1 articles | Depends on how smooth the thread needs to be but it can simply be done in increments moving the table then rotating the work and depending on form you may need to make up a cutter. I have seen other lash ups where the drive to the dividing head or rotary table was disengaged and various belts and pullies linked to the table handwheel so work turned when the table was moved which all seem to work OK and probably better than trying to drive the table from the dividing head Edited By JasonB on 08/03/2023 11:39:57 |
John Haine | 08/03/2023 11:39:47 |
5563 forum posts 322 photos | Prof Chaddock recommended cutting the column thread for the Quorn using a powered milling spindle on the lathe carriage, and driving the headstock mandrel from the leadscrew using a handle on the leadscrew. |
Martin Johnson 1 | 08/03/2023 12:45:50 |
320 forum posts 1 photos | Here is my set up for a steering box screw on a Tom Senior M1 and the usual Taiwan 6" rotary table: https://www.flickr.com/photos/140734312@N06/37334008234/in/album-72157669955074511/ Sorry dont know how to do a hyperlink. Martin Edited By JasonB on 08/03/2023 13:13:53 |
Clive Foster | 08/03/2023 14:15:44 |
3630 forum posts 128 photos | Martin Cunning set up. Driving the rotary table directly via a chain of gears was, for me, a classic "D'oh obvious" now someone has shown me thing. Would work just as well with a spindexer too. Brilliant lateral thinking. Many professional dividing heads, like my Cincinnati copy Edgewick have a drive shaft provided for this sort of use. Cincinnati had whole bolt on change wheel bracket, gear set and cover assembly to use their heads on their mills. My dividing head came with couple of chain and sprocket assemblies that were used to connect it to a Bridgeport for, as I recall it, some sort of mould making work. Clive |
John P | 08/03/2023 14:47:43 |
451 forum posts 268 photos |
I have done here almost the same as what you are trying to do at 1.480" dia |
Clive Foster | 08/03/2023 16:56:41 |
3630 forum posts 128 photos | John P Martins method of directly driving a rotary table, spin-dexer or simple spindle seems much more appropriate than attempting to drive a dividing head via its normal worm and wheel. Direct 1:1 drive will replicate the feedscrew pitch. Coarser pitches will need the rotary drive stepped down in the same ratio as the feedscrew and desired pitch. So, for example, if the feedscrew is 8 tip and the desired pitch 1" then 8:1 step down will do the deed. It's unlikely that any ratio be large enough to be wildly impractical. Its the method I shall adopt should I ever need to do "figure 8" oiling grooves. Admittedly producing a metric pitch on an imperial machine or imperial pitch on a metric machine will be tricky as the conversion gear(s) need to be arranged. Arranging temporary metric or imperial feedscrew using decent studding might be more attractive in that case. As Y-axis feed will not be needed once all is set up an external screw is feasible with the nut clamped to the Y dovetails. Clive |
