Robey 6-7hp Works traction engine drawings for sale.
Tom Antell25/02/2023 21:40:33
14 forum posts
have been sorting through what drawings I have and realised I have a near complete set except for one or two general arrangement drawings, clack valve and mud doors, but I can help with those details. This is a great opportunity for someone to have a go at making a model or even full size if they were daring enough (a good amount of patterns are already dotted around the country). Aside from that every other component part, nut and bolt to make one is included. Unlike what I have shared before these are professionally scanned drawings and not photographed copies. They cover 6 or 7hp single cylinder and compound traction engines/Road Locomotives 2 or 3 speeds. Half 3/4 or full length canopy drawings are also included. I do not have a 4 foot 6 solid flywheel drawing. But I do have a rough copy of a 4 foot solid flywheel that I have scaled up, as well as them appearing on some arrangement drawings. The set comprises of 97 drawings all in A1 size. The drawings included are listed below.
Tom Antell25/02/2023 21:48:40
14 forum posts
Winding-Forward-Drum-for-6-7hp-Traction-Engines.
Weigh-Shaft-Brackets-6-7hp-Compound-Traction-Engines.
Trunk-Guides-Weigh-Shaft-Bracket-Slide-and-Safety-Valve-for-6-7-hp-Traction-Engines.
Trunk-Guides-Slide-and-Safety-Valves-for-Compound-6-7hp-Traction-Engines.
Three-Speed-Gearing-for-6-7-hp-Traction-Engines.
Third-Motion-Shaft-and-Hind-Axle-Bearings-for-6-7hp-Traction-Engines-Without-Springs.
Stop-Valve-Details-for-6-7-8-10hp-Traction-Engines.
Steerage-Reversing-Lever-for-6-7hp-Traction-Engines.
Steerage-Reversing-Lever-6-7hp-Traction-Engines.
Steam-Elbow-for-Boiler-Front-6-7hp-Traction-Engines.
Standard-Water-Lifter-Hose-Pipe-Carriers-for-6-7-8-10hp-Traction-Engines.
Standard-Tender-for-67hp-Traction-Engines.
Standard-Sheet-Check-Valves-1.
Standard-Sheet-Blow-off-Cocks.
Standard-Boiler-Mountings-for-Tractors-and-Traction-Engines.
Standard-Boiler-for-6hp-Single-Compound-Traction-Engine.
Standard-Boiler-for-7hp-Single-Compound-Traction-Engine.
Spring-Gear-for-67hp-Traction-Engines.
Special-Road-Wheels-for-6hp-Traction-Engine-5ft-6-Dia.
Special-Hind-Road-Wheels-for-6-7hp-Traction-Engines-6ft6-Dia.
Special-Disc-Crankshaft-for-7hp-3-speed-Compound-Traction-Engine.
Special-Deep-Sided-Front-Tank-for-7hp-Traction-Engine.
Spark-Arrestor-Smokebox-door-for-6-7hp-Traction-Engines.
Shafts-Axles-for-67hp-Single-Compound-Traction-Engines.
Seating-for-Cylinder-Bored-Guide-Support-6-7hp-Traction-Engines.
Rope-Guide-Rollers-Rear-Tank-Fittings-for-6-7-8-10hp-Traction-Engines.
Road-Wheels-for-6-7hp-Traction-Engines-Road-Locomotive.
Rim-Brake-Gear-for-6-7hp-Traction-Engines.
Reversing-Gear-for-5-6-7hp-Traction-Engines.
Rack-for-Tender-67-8-10hp-Traction-Engines.
Position-of-Bearing-for-Tractors-Traction-Engines.
Pickering-Governor-Arrangement-6-7hp-Single-Tractions.
Pickering-Governor-Whistle-for-6-7hp-Traction-Engines.
Outline-Arrangement-6hp-Single-Cylinder-Traction-Engine.
Nameplates-on-Smokebox-Door-for-all-Traction-Engines.
Machined-Crank-6hp-Single-Cylinder-Traction-Engine.
Left-Hand-Reversing-Gear-Details-6-7hp-Traction-Engines.
Large-Boiler-for-6hp-Single-Compound-Traction-Engines.
Injector-Waterlifter-Arrangement-for-6-7hp-Traction-Engines.
Hind-Road-Wheels-for-6-7hp-Colonial-Traction-Engine-6ft-Dia.
Half-Canopy-for-67hp-Traction-Engines.
Guide-Bars-Slide-Safety-Valves-for-67hp-Single-Tractions.
General-Arrangement-7hp-Single-Cylinder-Traction-light-type.
Gearing-for-6-7hp-Traction-Engines.
Geared-Down-Pump-Details-67hp-Traction-Engine.
Gear-Guard-for-6-7hp-Traction-Engines.
Gear-Case-for-6-7hp-Hp-Traction-Engine-3-speed.
Gauge-Guard-for-58-and-12-Inch-Guages-Glasses.
Full-Length-Canopy-6-7hp-Traction-Engines.
Front-Tank-for-6-7hp-Tractions-Road-Locos.
Front-Tank-6-7hp-Tractions-and-Road-Locos.
Front-Tank-Steerage-for-6-7hp-Traction-Engines.
Fore-Carriage-Front-Wheels-Locking-Plate-for-6-7hp-Traction-Engines.
Flywheel-Brake-For-6-7hp-Traction-Engines.
Flared-later-design-Tender-6-7hp-Traction-Engines.
Fire-Hole-Doors-for-Tractors-Traction-Engines.
Feed-Pump-for-6-7hp-Traction-Engines.
Exhaust-Pipe-Flywheel-Chimney-Drain-Cocks-Footboard-Lagging-6-7hp-Traction-Engines.
Exhaust-Pipe-and-Governor-for-6-7hp-Compound-Traction-Engines.
Engine-Motion-Covers-for-6-7hp-Traction-Engines.
Disc-Flywheel-4-foot-Dia.
Details-of-3rd-Speed-Gear-6-7hp-Traction-Engines.
Cylinder-for-6-7hp-Single-Traction-Engine.
Cylinder-Cock-Gear-for-6-7hp-Comp-Traction-Engines.
Crankshaft-Second-Motion-Shaft-Bearings-6-7hp-Traction-Engines-red-lined.
Connecting-Rod-Piston-and-Crosshead-for-6-7hp-Single-Traction-Engines.
Con-Rods-Cross-Heads-Pistons-Rods-for-6-7-8-10hp-Traction-Engines.
Con-Rod-Piston-Crosshead-for-6-7hp-Traction-Engines.
Compound-Cylinders-for-6-7hp-Traction-Engines.
Class-A-Governor-for-6-7hp-Traction-Engines.
Canopy-Full-Length-Arrangement-Details-6hp-Traction-Engine-Large-Boiler.
Boiler-for-Special-6hp-Compound-Traction-Engine.
Bearings-for-6-7hp-Spring-Traction-Engines.
Balance-Weights-for-6-7hp-Compound-Traction-Engines.
Auxilary-Valve-for-Compound-Tractors-Tractions.
Automatic-Shop-Details-Nuts-Bolts-Pins-and-misc-parts-for-6-7hp-Traction-Engines.
Ashpan-Damper-Gear-Arrangement-6-7hp-Traction-Engine.
Arrangment-of-Platform-Ladder-6-7hp-Traction-Engine.
Arrangement-of-Single-Cylinder-Spring-Mounted-Road-Locomotive.
Arrangement-of-Reversing-Gear-6-7hp-Traction-Engines-Colonial-Type.
Arrangement-of-Piping-for-6-7hp-Single-Compound-Traction-Engines.
Arrangement-of-Pickering-Governor-6hp-Single-Cylinder-Traction-Engine.
Arrangement-of-Patent-Spring-Mounting-for-Traction-Engines.
Arrangement-of-Mechanical-Lubricator-6-7hp-Single-Cylinder-Traction-Engines.
Arrangement-of-Lubricator-for-6-7hp-Comp-Traction-Engines.
Arrangement-of-Geared-Down-Pump-for-67hp-Comp-Traction-Engine.
Arrangement-of-front-Tank-Steerage-6-7hp-Tractions-Road-Locos.
Arrangement-of-Compound-Road-Locomotive.
Arrangement-of-Boiler-Mountings-for-6-7hp-Traction-Engines.
Arrangement-of-Boiler-Fittings-6-7hp-Traction-Engines.
Arrangement-of-8x12-Direct-Ploughing-Engine.
Arrangement-of-5hp-Compound-Traction-Engine.
Arrangement-of-3-Speed-Gear-for-Traction-Engines.
18inch-Wide-Hind-Road-Wheels-for-7hp-Traction-Engine.
3rd-Motion-and-Hind-Axle-Bearings-for-6-7hp-Traction-Engines-Without-Springs.
2-Speed-Clutch-Gear-for-6-7-8-10hp-Traction-Engin
Tom Antell25/02/2023 21:49:48
14 forum posts
As well as the drawings I can supply digital copies of any works photographs or restoration photos of 6 and 7hp Traction Engines.
The price is £120 including postage. Please PM for more info.
Tom Antell25/02/2023 21:53:53
14 forum posts
Tom Antell25/02/2023 21:54:55
14 forum posts
Tom Antell25/02/2023 21:56:24
14 forum posts
Tom Antell25/02/2023 21:58:43
14 forum posts
Tom Antell25/02/2023 21:59:57
14 forum posts
Tom Antell25/02/2023 22:01:18
14 forum posts
Tom Antell25/02/2023 22:02:40
14 forum posts
Tom Antell25/02/2023 22:04:00
14 forum posts
Above is a selection of some of the drawings on offer, and a selection of all the different 6&7hp traction engine models you could potentially make from these drawings.
JasonB26/02/2023 06:55:09
Tom, suggest you use the For Sale Classifieds not the forum to sell things.
Tom Antell26/02/2023 16:30:38
14 forum posts
Thanks Jason, Im new to this group and didnt notice that area
