Member postings for Tom Antell
Here is a list of all the postings Tom Antell has made in our forums. Click on a thread name to jump to the thread.
Thread: Robey 6-7hp Works traction engine drawings for sale.
26/02/2023 16:30:38
Thanks Jason, Im new to this group and didnt notice that area
25/02/2023 22:04:00
Above is a selection of some of the drawings on offer, and a selection of all the different 6&7hp traction engine models you could potentially make from these drawings.
25/02/2023 22:02:40
25/02/2023 22:01:18
25/02/2023 21:59:57
25/02/2023 21:58:43
25/02/2023 21:56:24
25/02/2023 21:54:55
25/02/2023 21:53:53
25/02/2023 21:49:48
As well as the drawings I can supply digital copies of any works photographs or restoration photos of 6 and 7hp Traction Engines.
The price is £120 including postage. Please PM for more info.
25/02/2023 21:48:40
Winding-Forward-Drum-for-6-7hp-Traction-Engines.
Weigh-Shaft-Brackets-6-7hp-Compound-Traction-Engines.
Trunk-Guides-Weigh-Shaft-Bracket-Slide-and-Safety-Valve-for-6-7-hp-Traction-Engines.
Trunk-Guides-Slide-and-Safety-Valves-for-Compound-6-7hp-Traction-Engines.
Three-Speed-Gearing-for-6-7-hp-Traction-Engines.
Third-Motion-Shaft-and-Hind-Axle-Bearings-for-6-7hp-Traction-Engines-Without-Springs.
Stop-Valve-Details-for-6-7-8-10hp-Traction-Engines.
Steerage-Reversing-Lever-for-6-7hp-Traction-Engines.
Steerage-Reversing-Lever-6-7hp-Traction-Engines.
Steam-Elbow-for-Boiler-Front-6-7hp-Traction-Engines.
Standard-Water-Lifter-Hose-Pipe-Carriers-for-6-7-8-10hp-Traction-Engines.
Standard-Tender-for-67hp-Traction-Engines.
Standard-Sheet-Check-Valves-1.
Standard-Sheet-Blow-off-Cocks.
Standard-Boiler-Mountings-for-Tractors-and-Traction-Engines.
Standard-Boiler-for-6hp-Single-Compound-Traction-Engine.
Standard-Boiler-for-7hp-Single-Compound-Traction-Engine.
Spring-Gear-for-67hp-Traction-Engines.
Special-Road-Wheels-for-6hp-Traction-Engine-5ft-6-Dia.
Special-Hind-Road-Wheels-for-6-7hp-Traction-Engines-6ft6-Dia.
Special-Disc-Crankshaft-for-7hp-3-speed-Compound-Traction-Engine.
Special-Deep-Sided-Front-Tank-for-7hp-Traction-Engine.
Spark-Arrestor-Smokebox-door-for-6-7hp-Traction-Engines.
Shafts-Axles-for-67hp-Single-Compound-Traction-Engines.
Seating-for-Cylinder-Bored-Guide-Support-6-7hp-Traction-Engines.
Rope-Guide-Rollers-Rear-Tank-Fittings-for-6-7-8-10hp-Traction-Engines.
Road-Wheels-for-6-7hp-Traction-Engines-Road-Locomotive.
Rim-Brake-Gear-for-6-7hp-Traction-Engines.
Reversing-Gear-for-5-6-7hp-Traction-Engines.
Rack-for-Tender-67-8-10hp-Traction-Engines.
Position-of-Bearing-for-Tractors-Traction-Engines.
Pickering-Governor-Arrangement-6-7hp-Single-Tractions.
Pickering-Governor-Whistle-for-6-7hp-Traction-Engines.
Outline-Arrangement-6hp-Single-Cylinder-Traction-Engine.
Nameplates-on-Smokebox-Door-for-all-Traction-Engines.
Machined-Crank-6hp-Single-Cylinder-Traction-Engine.
Left-Hand-Reversing-Gear-Details-6-7hp-Traction-Engines.
Large-Boiler-for-6hp-Single-Compound-Traction-Engines.
Injector-Waterlifter-Arrangement-for-6-7hp-Traction-Engines.
Hind-Road-Wheels-for-6-7hp-Colonial-Traction-Engine-6ft-Dia.
Half-Canopy-for-67hp-Traction-Engines.
Guide-Bars-Slide-Safety-Valves-for-67hp-Single-Tractions.
General-Arrangement-7hp-Single-Cylinder-Traction-light-type.
Gearing-for-6-7hp-Traction-Engines.
Geared-Down-Pump-Details-67hp-Traction-Engine.
Gear-Guard-for-6-7hp-Traction-Engines.
Gear-Case-for-6-7hp-Hp-Traction-Engine-3-speed.
Gauge-Guard-for-58-and-12-Inch-Guages-Glasses.
Full-Length-Canopy-6-7hp-Traction-Engines.
Front-Tank-for-6-7hp-Tractions-Road-Locos.
Front-Tank-6-7hp-Tractions-and-Road-Locos.
Front-Tank-Steerage-for-6-7hp-Traction-Engines.
Fore-Carriage-Front-Wheels-Locking-Plate-for-6-7hp-Traction-Engines.
Flywheel-Brake-For-6-7hp-Traction-Engines.
Flared-later-design-Tender-6-7hp-Traction-Engines.
Fire-Hole-Doors-for-Tractors-Traction-Engines.
Feed-Pump-for-6-7hp-Traction-Engines.
Exhaust-Pipe-Flywheel-Chimney-Drain-Cocks-Footboard-Lagging-6-7hp-Traction-Engines.
Exhaust-Pipe-and-Governor-for-6-7hp-Compound-Traction-Engines.
Engine-Motion-Covers-for-6-7hp-Traction-Engines.
Disc-Flywheel-4-foot-Dia.
Details-of-3rd-Speed-Gear-6-7hp-Traction-Engines.
Cylinder-for-6-7hp-Single-Traction-Engine.
Cylinder-Cock-Gear-for-6-7hp-Comp-Traction-Engines.
Crankshaft-Second-Motion-Shaft-Bearings-6-7hp-Traction-Engines-red-lined.
Connecting-Rod-Piston-and-Crosshead-for-6-7hp-Single-Traction-Engines.
Con-Rods-Cross-Heads-Pistons-Rods-for-6-7-8-10hp-Traction-Engines.
Con-Rod-Piston-Crosshead-for-6-7hp-Traction-Engines.
Compound-Cylinders-for-6-7hp-Traction-Engines.
Class-A-Governor-for-6-7hp-Traction-Engines.
Canopy-Full-Length-Arrangement-Details-6hp-Traction-Engine-Large-Boiler.
Boiler-for-Special-6hp-Compound-Traction-Engine.
Bearings-for-6-7hp-Spring-Traction-Engines.
Balance-Weights-for-6-7hp-Compound-Traction-Engines.
Auxilary-Valve-for-Compound-Tractors-Tractions.
Automatic-Shop-Details-Nuts-Bolts-Pins-and-misc-parts-for-6-7hp-Traction-Engines.
Ashpan-Damper-Gear-Arrangement-6-7hp-Traction-Engine.
Arrangment-of-Platform-Ladder-6-7hp-Traction-Engine.
Arrangement-of-Single-Cylinder-Spring-Mounted-Road-Locomotive.
Arrangement-of-Reversing-Gear-6-7hp-Traction-Engines-Colonial-Type.
Arrangement-of-Piping-for-6-7hp-Single-Compound-Traction-Engines.
Arrangement-of-Pickering-Governor-6hp-Single-Cylinder-Traction-Engine.
Arrangement-of-Patent-Spring-Mounting-for-Traction-Engines.
Arrangement-of-Mechanical-Lubricator-6-7hp-Single-Cylinder-Traction-Engines.
Arrangement-of-Lubricator-for-6-7hp-Comp-Traction-Engines.
Arrangement-of-Geared-Down-Pump-for-67hp-Comp-Traction-Engine.
Arrangement-of-front-Tank-Steerage-6-7hp-Tractions-Road-Locos.
Arrangement-of-Compound-Road-Locomotive.
Arrangement-of-Boiler-Mountings-for-6-7hp-Traction-Engines.
Arrangement-of-Boiler-Fittings-6-7hp-Traction-Engines.
Arrangement-of-8x12-Direct-Ploughing-Engine.
Arrangement-of-5hp-Compound-Traction-Engine.
Arrangement-of-3-Speed-Gear-for-Traction-Engines.
18inch-Wide-Hind-Road-Wheels-for-7hp-Traction-Engine.
3rd-Motion-and-Hind-Axle-Bearings-for-6-7hp-Traction-Engines-Without-Springs.
2-Speed-Clutch-Gear-for-6-7-8-10hp-Traction-Engin
25/02/2023 21:40:33
have been sorting through what drawings I have and realised I have a near complete set except for one or two general arrangement drawings, clack valve and mud doors, but I can help with those details. This is a great opportunity for someone to have a go at making a model or even full size if they were daring enough (a good amount of patterns are already dotted around the country). Aside from that every other component part, nut and bolt to make one is included. Unlike what I have shared before these are professionally scanned drawings and not photographed copies. They cover 6 or 7hp single cylinder and compound traction engines/Road Locomotives 2 or 3 speeds. Half 3/4 or full length canopy drawings are also included. I do not have a 4 foot 6 solid flywheel drawing. But I do have a rough copy of a 4 foot solid flywheel that I have scaled up, as well as them appearing on some arrangement drawings. The set comprises of 97 drawings all in A1 size. The drawings included are listed below.
Thread: Free Robey Tractor/Traction/Road Loco Drawings
05/03/2018 13:37:03
The online folder contains the following
Engine register listing
K66 Robey Tractor Drawings
K67 Robey 6-7hp Traction Engine Drawings
K68 Robey 8hp Traction Engine Drawings
Works Photographs
Boiler Fittings
The files can be found in the onedrive folder below
Cheers
Tom
Thread: Robey 5 Ton tractor
05/03/2018 13:27:11
Hi Maurice, I have a set of robey tractor/traction/road loco
drawings that you may want to take a look at including detailed workshop photographs.
You will find them on the link below
Many Thanks
Tom
