Attempting to install …
Michael Gilligan | 22/02/2023 15:14:06 |
![]() 23121 forum posts 1360 photos | This is a Windows-specific program, so I dug-out my little Samsung NetBook, which runs Windows 7 The download is available at: **LINK** https://picaxe.com/software/picaxe/picaxe-editor-6/index.html#download and there is a helpful note there about .Net Framework 3.5.1 … So far, so good. But when I try to install the PicAxe software, it warns me about .Net needing to be installed [which it is] and it fails with the error message: PICAXE Editor Installer Information Error 2732. Directory Manager not initialized. . Help … Please !! MichaelG.
Ady1 | 22/02/2023 15:20:31 |
![]() 6137 forum posts 893 photos | Probably an update gets it going I had to download something for my world of tanks a few months ago, not happy to do it but I did ...and Alibre V23 suddenly worked flawlessly on my W7 64 bit system I've tried to find what it was for you but I haven't found it yet edit: oh you lucky dog, I found it Now this may not fix things, but it didn't mess me up either and Alibri magically got up and running Edited By Ady1 on 22/02/2023 15:24:24 |
Michael Gilligan | 22/02/2023 15:41:30 |
![]() 23121 forum posts 1360 photos | Thanks for that Ady I did a ‘normal’ update on the machine before I started … but there is a long list of ‘optional’ updates that I have never installed, so I will check through those later. Need to go out to buy food and drink now ! MichaelG. |
Grizzly bear | 22/02/2023 18:50:32 |
337 forum posts 8 photos | Michael, Plenty of info on the Picaxe forum. You are not on your own. Search results for query: Picaxe installation | PICAXE Forum Good luck.......... |
Michael Gilligan | 22/02/2023 20:57:42 |
![]() 23121 forum posts 1360 photos | Thanks, Bear I had already been looking on the PicAxe forum, and getting nowhere, before I posted here … and didn’t do much better when I tried again So I continued to install the few optional updates which Micro$oft would download, including the upgrade of .Net from 3.5.1 to 4.8 It said this had been installed successfully but [surprise, surprise] the list of installed ‘Windows features’ still lists 3.5.1 and there is no sign of 4.8 …. Took a deep breath and engaged ‘infinite number of monkeys’ mode: I turned the little group of .Net features on and off in all permutations, and finally settled for all off. Ran the installer again, and this time it worked [various expletives deleted] I wasn’t taking notes but, I think it comes down to:
This all seems utterly bonkers to me The screen of the NetBook is really too small for the software to display conveniently … but at least it seems to work. I will be back if it all goes horribly wrong !! MichaelG. . Edit: __ sorry, had to correct step 4 All three boxes for the [now non-existent] .Net 3.5.1 are ticked.
Edited By Michael Gilligan on 22/02/2023 21:11:09 |
Nicholas Farr | 23/02/2023 21:49:29 |
![]() 3988 forum posts 1799 photos | Hi MichaelG, firstly I don't have PicAxe, but I do have an old favourite scanning and editing programme which was for Windows 3.1 / 95 / NT, while it worked just as well on Windows 98 and 98 2nd edition, it would also work on Windows 2000, but would freeze after a while when using it. It will also work on Vista reasonably well, though it's fussy which scanner I use it on, and it does work really well on Windows XP with all scanners that I've had, but the only laptop I have with XP on is a Toshiba N100 notebook, which only has a screen size of 8.9 inch's, which makes it hard to see if drawings and text are square to the page. Luckily it has an output for an external monitor, which overcomes the problem of lining up the small scanned page correctly, as very often printed stuff isn't very square to the paper it's printed on. A couple of photos below show the difference, one of the pre-scan and one of a zoomed in area to check the lining up. The External monitor is a spare 20 inch one that I have. Regards Nick.
Edited By Nicholas Farr on 23/02/2023 21:53:51 |
Michael Gilligan | 23/02/2023 22:12:04 |
![]() 23121 forum posts 1360 photos | Thanks, Nick … Yes, the little Samsung NetBook [whose screen is only 1024x600] also has a VGA port, so it’s no great problem. I’ve just got spoiled using the iPad with its high-resolution screen. MichaelG. Edited By Michael Gilligan on 23/02/2023 22:17:03 |
