Dougie Swan | 14/02/2023 18:27:30 |
269 forum posts 73 photos | Hi I have searched everywhere but can't find a source for copper washers to fit a standard glow plug or 1/4 x 32 spark plugs Can anyone help Thanks Dougie |
Ramon Wilson | 14/02/2023 18:39:30 |
![]() 1655 forum posts 617 photos | Dougie - I may be wrong but I don't think you will. In a lifetime of aeromodelling I don't think I've ever seen any as 'spare washers'. All the glow plugs I've bought always came with one. It's easy enough to turn one though if you have some copper bar but make sure you anneal it before using it. How many do you need? Best Tug |
JasonB | 14/02/2023 18:40:20 |
![]() 25215 forum posts 3105 photos 1 articles | Minimag do them for the 1/4 x 32 spark plugs which will fit. You can also get various thickness copper shim washers from several of the ME suppliers that are used to adjust the position of screw in steam fittings but they tend to be a bit thinner |
Dougie Swan | 14/02/2023 18:59:57 |
269 forum posts 73 photos | Thanks for the replies Once again Jason you have come up trumps Thankyou Dougie |
Ramon Wilson | 14/02/2023 20:20:56 |
![]() 1655 forum posts 617 photos | Well there you go Dougie - you (one) can learn something everyday! A glow plug washer is usually much thicker that the shim washers for steam fittings though of course useable if the plug doesn't go in too far on some engines.
Edited By Ramon Wilson on 14/02/2023 20:21:11 |
Neil Lickfold | 15/02/2023 09:11:42 |
1025 forum posts 204 photos | Usually the plug washers are 0.8mm thick or 1/32 of an inch. I did not see a thickness for the washers for spark plugs, but they will work for glow plugs. An interesting thing about the 1/4 - 32 glow plugs, is of the plug body enters into the chamber a little bit, a better performance has often been noticed. It is not from the small gain in compression ratio, but to to the gain of how the fuel is ignited and burnt. The same is being investigated with spark engines too. |
