Myford..?
Les Geds | 08/02/2023 00:05:43 |
9 forum posts 6 photos | Can anyone recognise what model myford lathe this is.
Ady1 | 08/02/2023 00:16:11 |
![]() 6137 forum posts 893 photos | probbly a Myford ML4 Lathes.co.uk will help you |
Les Geds | 08/02/2023 00:20:48 |
9 forum posts 6 photos | Thanks Ady1 will have a look. |
Howard Lewis | 08/02/2023 11:41:48 |
7227 forum posts 21 photos | The edarly Myfords were distinguished by the centre height and centre distance. the ML 1 was 3.125 centre height, and was 15" centres,, from memory (Dheck with Lathes UK ) The ML3 was 3.5" centre height, 15" centres, and the Ml4 was, like the ML2 a greater centre distance. The thread for the chucl, originally was 7/8 BSW, (7/8 x 9 tpi ) but later was changed to 7/8 x 12 tpi. Possibly, some of the very last were 1 1/8 x 12 tpi, but lacked the 1 1/4" register used on nthe ML7 A peculiarity is that there is no gear in the Saddle so that moves the opposite way to the handle rotation. i.e..Clockwise rotation of the handle moves towards the Headstock The gears ar 20 DP, 14.5 PA but are driven, (by driving collars on the spindle and Leadscrew ) or compounded by 3/32 pins, rather than the keys used on the ML7. The bore and width of 7 Series gears is the same, so by drilling through an existing gear, it can be used as jig to drill a 7 Series gear for use on the earlier Mls. But try not to drill right through, so that the opin is retained. Threads will be 1/4 BSF , mostly with a few BSW included. The gib screws ar probably BA. For full details, look at lathes UK pages on the Ml1, 2, 3 and 4. It may be ols, but if in reasonable trim is quite useabl. It bmight be nworth getting an extra 20T or two, so that a fine feed can be set up 20:60/20:65/20:60 on the Leadscrew. This should give a fine feed of abouyt 0.004" per rev. Yiou may need to fettle the spindle end of the banjo. to allow the stud to give good gear mesh. The Tailstock barrel is prevented from rotating by a 1/4 BSF grubscrew with a key in the end that engages the keyway in the barrel. Once adjusted, it is secured by a locknut. It might well be worth making an adaptor so that the later 1.125 / 1.25 register "standard" Myford fitting chucks can be fitted. I did this for somone who acquired a ML4, which we eventually got sorted and useable. HTH Howard |
Robert Atkinson 2 | 08/02/2023 14:35:53 |
![]() 1891 forum posts 37 photos | Howard, That is incorrect. According to contempary Myford literature: ML1 and ML2 are 3-1/8" center height 8.6" swing (in gap) and 15" Capacity (assume between centers). ML3 and ML4 are 3-1/2" center height, 10" swing and 24" capacity. The ML2 and ML4 were "superior" models with sthouded thrust bearings, bronze spindle bearings, longer cross-slide and quick release tailstock. Lathes.co.uk was / is wrong / inconsistent in the descriptions. ML1/2 and ML3/4 are easilly differentiated by bed length. For ML1/3 and 2/4 differntiation you need to check the bearings in the headstock. They did not make a 3-1/8" x 24" model (or 3-1/2" x 15" EDIT the OP's lathe is either a ML3 or ML4. cross side loks like ML4 Robert.
Edited By Robert Atkinson 2 on 08/02/2023 14:37:43 |
Philip Rowe | 08/02/2023 16:58:44 |
248 forum posts 33 photos | And also the ML1 had the headstock and bed as a single casting, from the ML2 onwards the headstock was a separate casting retained by bolts. Phil |
