Andrew David | 31/01/2023 14:18:37 |
![]() 31 forum posts 7 photos | In my drill press (make Jet JDP 17F) , on the junction box by the side of the machine , there is some sort of push button . It looks like a reset switch . But what does it reset? Can |
Speedy Builder5 | 31/01/2023 14:35:03 |
2878 forum posts 248 photos | Overload protection cutout switch. Push it back in if the motor doesn't turn. ?? |
Jeff Dayman | 31/01/2023 16:39:49 |
2356 forum posts 47 photos | Does one cable going to the box have the power supply plug? Does the other cable go to the motor? if so the button is probably the reset for a thermal circuit breaker to cut off the power to the motor if it draws too much current in an stall or overload situation. If the cables are routed elsewhere I have no idea what it resets. Is there a lamp mounted integral to the drill press anywhere? could be a switch for the lamp if so. My drill press has a lamp in the housing behind the spindle and in front of the column. |
John Haine | 31/01/2023 17:53:02 |
5563 forum posts 322 photos | There was one looking a bit like this on the contactor box on my VMB mill. Does it have a flexible silicone cap? I think it's actually an air-pressure operated emergency switch, which can be linked by a tube to some sort of bellows to link up a remote e-stop. It was one of the several bits of the contactor that gave up the ghost! |
Andrew David | 31/01/2023 18:54:46 |
![]() 31 forum posts 7 photos | When i push it in, nothing seams to engage . The main power comes to this box and from there it goes to the NVR, and some wires go to this switch as well. As speedy says, it could be an overload cutout switch. Any way, soon i am going to get rid of all this and going to install a 3 phase motor with VFD with its on control box. Thanks. Andrew. |
Ady1 | 31/01/2023 23:24:33 |
![]() 6137 forum posts 893 photos |
