gear milling
software for milling gears, straight and helical on cnc 4 axis mill
Vasantha Abey31/01/2023 11:17:06
17 forum posts
Hear is a software to mill gears with automatic g code generation. You need to either use a hand ground end mill two lipped to get a correct involute form,mount it on the vertical spindle. bring the cutter to the start point preferably X0 of G0 code.
you can also use a std milling cutter from the side of the head head angled to suit helix angle.
the distance you want to cut is after the code generation.
WARNING. please dont mess with the software input window. Just input Number of teeth,, length of teeth, angle between to start face and end face..
Here is how the inputing window looks like
Number of teeth.
Face width
Angle Between Faces
Invert rotation (FOR LH OR RH)
Dont change unless you know what you are doing. Please write down the letters, correct spaces, * asteric etc. If you mess up write as original and it will work.
Unfortunately in this thread there is no link to upload the simple software I have unless you email me.
its on the web as
Acerca de gcode_helgears Version 1.0
regards every one
Vasantha
John Haine31/01/2023 11:25:42
5563 forum posts
322 photos
Hi Vasantha, that sounds very interesting, thanks for sharing this. Google fails to find the software from the description, please could you post a direct link?
Michael Gilligan31/01/2023 13:01:15
23121 forum posts
1360 photos
Curiouser, and Curiouser [said Alice]
I have just done a little search, and Google found two hits … both of which appear to contain the same URL
I will leave the Eat Me/Drink Me decision to you.
But I think you might search for gcode_helgears.zip
Edited By Michael Gilligan on 31/01/2023 13:02:05
JasonB31/01/2023 13:10:23
Posted by Vasantha Abey on 31/01/2023 11:17:06:
That does not sound ideal and will require some calculation. It's usual to just specify the helix angle not what angle is at start and finish (I assume this is the rotation of the gear blank) Length of tooth is that along the helix, again needs prior calculations.
It would be better to enter the usual known helix angle and width of gear and then use the software to generate the code from that
Martin Connelly31/01/2023 14:56:41
2549 forum posts
235 photos
Vasantha
Martin C
