Andre ROUSSEAU | 25/01/2023 05:05:50 |
90 forum posts 1 photos | The mind boggles...! |
Speedy Builder5 | 25/01/2023 06:52:28 |
2878 forum posts 248 photos | Very interesting but does it have a practical application ? Bob |
Nigel Graham 2 | 25/01/2023 11:17:55 |
3293 forum posts 112 photos | Hard to think of practical application for a thread of that form. As for the video, once I'd endured the irrelevant ads including an American one for a product allegedly sold in the UK, I gave up on the video itself even before the machinist with St. Vitus' Dance had even reached the far side of the woods. I had gathered he was supposed to make something like the screw in the catalogue picture he showed us below The Sign of the Swinging Lamp. I can't be doing with gimmicks, over-acting and time-wasting. Zig-zag multiple threads though? I suspect the booklet image was an example to show what the company could make, not what it normally made. Hard to think of any real use of such a thread, not already met in simpler ways. Nevertheless, over the years designers did create some wonderful drives for specific results, including square and elliptical gears, which give continuous rotations with continually-alternating ratios. ' A variation of that "zig-zag thread", with smooth transitions between directions, might give a continuously reversing drive of several rotations per stroke; but would still need some form of homing mechanism. Otherwise it shows an exercise in Advanced Turning and Metal-Puzzle Making, but then what? Overlapped threads of both hands though, are real...... . These are on reversing lead-screws, having left and right-hand, single-start threads of the same pitch on the same shaft. The two threads meet in a short but smooth return at each end of the shaft. The "nut" on the examples I saw is really a follower, typically a pivoting, lozenge-shaped block or a roller; but other machines might use perhaps a recirculating-ball nut. I have seen such lead-screws on special winches, driving a fairlead back and forth to wrap the "cable" properly over several layers. The pitch is that of the "cable" wrapped fully, in lateral but uncompressed contact; and the lead-screw is obviously geared to the drum in the correct ratio. (The covers probably hid timing-belts and toothed pulleys.) Such a screw allows relatively very long strokes at constant speed in a very compact format. So another possible application might be driving a shaper or planer, provided having no "quick return" is unimportant, although the stroke cannot be varied except by changing the screw. It would though spread the wear evenly along the whole length of the ram and ways. It might be one way to convert a manual to powered shaper, and making the screw (best milled) would be an interesting exercise. . (Some winches using conventional wire-ropes guide the base wrap by a single-start "thread" of semicircular profile with attenuated crests, of pitch equal to cable diameter, cut in the drum surface. Once that first wrap is complete, its own surface guides the return wrap. On the particular winch I have operated, with a threaded drum, the fairlead is simply a hard, flat plastic strip the length of the drum. This works because the distance to the block is an open span of some 10 - 15 metres. The reversal used to create quite a shock as the cable jumped up onto the foundation layer, greatly reduced by fitting a snubber - just a convex plastic block - at each end to ease the cable over. )
Nicholas Farr | 25/01/2023 11:47:49 |
![]() 3988 forum posts 1799 photos | Hi Nigel, I don't think it had any real practical use, and I don't think it was intended too. I believe it is a novelty item that shows some very cleaver design and machining, along with the patience to do it with a bit of quirky humour, But he did make it with a place to hide some paper money or other treasures inside the bolt, but you wouldn't know just by looking and handling the bolt. I actually liked it. Regards Nick. |
Bazyle | 25/01/2023 11:52:36 |
![]() 6956 forum posts 229 photos | Interesting lathe. Any idea what it is? |
Jelly | 26/01/2023 11:38:53 |
![]() 474 forum posts 103 photos | Posted by Bazyle on 25/01/2023 11:52:36:
Interesting lathe. Any idea what it is? An 1И611П (Pronounced: "a'deen Ee shest'sot odinnadtsat' Pe") produced by IZH in Izhevsk. In the UK and west more generally they would be branded Stanko or StankoImport, so it was originally sold behind the iron curtain; you can see a familial resemblance in the pictures of the much larger Stanko 1K62 on Lathes.co.uk IZH is the USSR's internal branding of the machine tools from IZhMASh (Izhévsky mashinostroítelny Zavod), which is now part of the Kalashnikov Concern defence conglomerate. As far as I can tell, they have been making machine tools since their inception in the early 1800's (it was originally a government arsenal under the Tsar's, and the principles of building accurate metal lathes derived 50 years prior by Andrey Nartov in St. Petersburg being well known in russia by then)... But, machine tools are only a means to an end for them, with the main output of the factory being ten's of millions of different types of small arms, naval autocannon's in air-defense mounts, naval guns, and even various types of 8x8 and 10x10 trucks.
Looks like they're pretty well documented and supported... if you speak fluent russian with technical vocabulary Edited By Jelly on 26/01/2023 11:58:58 |
