Replacement pot
Chris Bakery’s | 14/01/2023 15:22:33 |
7 forum posts | hi sorry if this is in the wrong area, I have Chester super conquest mill which has a variable resistor (potentiometer) to control the speed, it also has a switch at the bottoms end of the speed range. The switch stopped working a long time ago but sadly the only one that Chester could supply was too small and the wrong. Does anyone know where I can get a replacement .
David George 1 | 14/01/2023 16:07:29 |
![]() 2110 forum posts 565 photos | If you can give a little more details and possibly a picture it would help. You need any informstion on the head how many connections, the hole size it fastens through etc. https://uk.rs-online.com/web/ Try these David
Ketan Swali | 14/01/2023 16:20:15 |
1481 forum posts 149 photos | If your mill looks like this then look at this page to see if the pot is the same. Ketan at ARC |
Chris Bakery’s | 14/01/2023 17:09:42 |
7 forum posts | Hi Ketan the picture of the miller looks similar but the pot looks identical. I see on the same page that you also sell the X and Y axis nuts. i have been trying to get these for over a year. Thanks for your help |
Chris Bakery’s | 14/01/2023 17:32:47 |
7 forum posts | Hi David thanks for the post i have looked at rs but can not see any switched pots. I was going to give them a call. The only markings on the pot are 4k7 so I assume that it is a 4700 ohm. If I can find a suitable pot “I will make it fit” |
Ketan Swali | 14/01/2023 18:11:29 |
1481 forum posts 149 photos | Hi Chris, I am a little confused. If you click on the picture of the pot on the spares page, you will see the details which show that it is switched pot. Is it different from the one you are looking for? |
Chris Bakery’s | 14/01/2023 18:36:52 |
7 forum posts | Hi Ketan sorry if I confused you the pot looks exactly the same. i also need the x and y axis nuts shown on the same page so I will give arc a call on Monday |
ALLAN QURASHI | 14/01/2023 21:43:51 |
24 forum posts 4 photos | Hi Chris, omeg.co.uk/potentiometers/ are worth a try. You'll be spoilt for choice. You might have to google it because the forum machine wouldn't let me copy & paste an actual link. Good luck
Edited By ALLAN QURASHI on 14/01/2023 21:47:46 |
Chris Bakery’s | 16/01/2023 17:18:52 |
7 forum posts | Hi All Just a quick update to thank all the people who took the time to reply. I checked with Arc Euro who are reasonably close to me and they provided exactly the pot that I needed. I also picked up the two lead screw nuts that I have been after for over a year. I now have a mill with very little backlash😀, climb milling here I come. |
