How to release MT1 taper
Rowan Sylvester-Bradley29/11/2022 15:01:49
88 forum posts
How do I release the tailstock MT1 chuck or centre from my Portass PD5 lathe?
Thank you - Rowan
Nicholas Farr29/11/2022 15:20:07
3988 forum posts
1799 photos
Hi Rowan, if the tailstock barrel is the hollow type, a piece of steel bar, probably 3/8" diameter long enough to reach the Moorse tapper, and then hit the end of the bar with a hammer.
Regards Nick.
Clive Foster29/11/2022 15:32:40
3630 forum posts
128 photos
Rowan
As Nicholas says the tailstock poppet barrel is hollow. Either a gentle tap with a hammer on a suitable drift as Nicholas suggests or make up a slide hammer style knocker by using a longer drift with a handle on the end. Spare file handle perhaps or just a simple graspable size lump of metal.
My experience of loose drift rods is that they to be good at the self hiding thing and vulnerable to being used as stock material. Something slightly more engineered hung on a hook close to the machine or held by a terry clip tends to be easier to find.
Brian Wood29/11/2022 15:37:13
2742 forum posts
39 photos
Hello Rowan,
I can confirm that having just looked up the model on www.lathes.co.uk which shows a hollow tailstock barrel. You may find the archive material on that site interesting. My father's ML4 bought in 1945 had a very similar tailstock and he kept a long bolt with a flat plate end to it as the knock out
Regards Brian
Edited By Brian Wood on 29/11/2022 15:39:56
ega29/11/2022 17:18:23
2805 forum posts
219 photos
Posted by Clive Foster on 29/11/2022 15:32:40:...
Users of the Myford lever-operated tailstock can simply unclamp the lever and use that as a drift; to facilitate this my clamp has a ball handle. I mostly use a drawbar, however, and this is loosened a couple of turns and tapped to release the taper tool (the copper hammer is in a terry clip!).
old mart29/11/2022 20:42:49
4655 forum posts
304 photos
It would lessen the impact forces on the threads and nut if the quill was locked before removing the tooling.
Mike Poole29/11/2022 21:52:38
3676 forum posts
82 photos
My preference is for a brass bar or at least a brass tip on the end to avoid any harm to the tool being ejected. Probably not absolutely necessary but it can’t do any harm.
Ady130/11/2022 01:04:37
6137 forum posts
893 photos
I got fed up of banging mine out with a hammer and drift and made a 6mm slot like the big drills have
Sometimes they can get pretty tight
Tap the taper release drift to shove it out, its a roundbar welded to the back of a triangular flatbar
And always remember to lock the tailstock and tailstock spindle before assaulting it by whatever means you employ
Edited By Ady1 on 30/11/2022 01:18:30
Peter Greene30/11/2022 01:32:54
865 forum posts
12 photos
Rowan
Mine's a piece of hex bar, maybe 18" long, stood in the corner by the lathe. Definitely low-tech. I just slide it in and, with about an inch to go, sort of throw it like a javelin (while loosely holding whatever's in the barrel with the other hand of course). The mass of the bar is enough - no hammers or anything fancy. been using the same bar for 20 years (it's shorter now though)
Macolm30/11/2022 17:27:04
185 forum posts
33 photos
Not tried this, but might work to dislodge a tight Jacobs taper.
Drill centrally through the chuck as suggested previously, but make it a small hole for a tight fit on a 3mm (say) steel rod. Now with the arbour downwards, fill the space with oil. Enter the rod (only just) and strike it sharply with a hammer to pressurise the space. The difference in areas should multiply the force on the end of the arbor
Some of us will have removed plain bushes from a blind housing in a similar way. It is surprising that this works even with a very loose fit, but the leakage is small for a sharp blow.
