Drive problems
CHRISTOPHER LYNCH | 27/11/2022 13:13:39 |
3 forum posts | Can anyone help please I have a Mk 2 Dore Westbury vertical milling machine. It wont drive the cutting head properly. OK on the fastest speed but just slips on the middle/lower setting. Assume the problem is with the speed reduction gearing but cannot work out exactly what the problem is. Many thanks in advance Chris |
bernard towers | 27/11/2022 13:56:36 |
1221 forum posts 161 photos | As its an epicyclic set up is it possible that one of the three elements is managing to slip under load? |
Zan | 27/11/2022 13:59:04 |
356 forum posts 25 photos | Is the problem on direct hogh speed drive or in the slow range? |
ChrisLH | 27/11/2022 14:13:45 |
111 forum posts 7 photos | There are two pegs which fit the large ali drum. In normal mode. They are fitted axially from underneath and connect two rotating drums. In low speed mode they are removed and refitted radially connecting the outer drum to the static partn of the machine. Hopefully this addresses the problem and you are able to see what is wrong. A full explanation would require drawings and diagrams. |
Brian Wood | 27/11/2022 15:58:35 |
2742 forum posts 39 photos | If the set up that Chris L above has suggested doesn't work then the problem lies with the fit of the reduction gearing. The build instructions stated the joints involved were to be loctited but either one or of those joints is now probably slipping I had exactly this problem on mine drilling holes approaching 20 mm diameter and you could hear churning noises from within the gearbox. I wrote up my fix in MEW 315 Regards Brian |
CHRISTOPHER LYNCH | 28/11/2022 08:25:46 |
3 forum posts | Thanks all for your comments I'll do some further investigations
CHRISTOPHER LYNCH | 28/11/2022 19:34:59 |
3 forum posts | Gentlemen, thank you very much for your advice. problem solved, it was the 2 pegs as per Chris LH. Every day is a school day! Chris |
Brian Wood | 29/11/2022 09:52:38 |
2742 forum posts 39 photos | Hello Chris, Thank you for the feedback, always good to hear the outcome of these difficulties, well done Chris LH Regards Brian |
ChrisLH | 29/11/2022 10:50:37 |
111 forum posts 7 photos | Thanks chaps, made my day. Chris LH |
