Second hand ones I have seen-queries
File Handle | 18/11/2022 17:53:30 |
250 forum posts | Recently I saw 2 horizontal boilers in an antique centre. Approx 3 x 6". They are mounted on a thin sheet rectangle with a "fire hole". Top of boiler has wooden cladding. I presume that they are designed for a meths or gas boiler. Several bushes are fitted, one of the boilers has a pressure gauge and water level indicator. I assume that they are a part completed project. Priced at £75 each - would this seem a reasonable price? (I know not an easy question to answer unseen) |
Nigel Graham 2 | 18/11/2022 21:15:40 |
3293 forum posts 112 photos | That would be a most unusual arrangement, vertical fire-tubes in a horizontal boiler. They'd need a smokebox along the the top of the shell; perhaps with the chimney in the centre, but from what you say this is not the case here. Are they actually fire-tubes, or in fact a form of thermic syphon, so full of water in use? That is quite common on small horizontal boilers made for gas or liquid-fuel, with the burner heating the entire length of the shell. As for value... I could not say but it would depend heavily on their condition, and evident signs of good workmanship would be a start. It'd be worth asking if the shop also has any model engines etc, that look as if intended to accompany these boilers; or at least came from the same seller.. |
Paul Lousick | 19/11/2022 00:32:30 |
2276 forum posts 801 photos | From the description, it is one design that I have never seen. Once again a photo is worth a 1000 words in describing it for a sensible answer. |
Hopper | 19/11/2022 04:34:11 |
![]() 7881 forum posts 397 photos | Sounds more like water tubes sticking out he bottom of the drum. Google Stuart 500 Model Boiler and have a look at a few examples showing the water tubes. |
fizzy | 19/11/2022 08:14:33 |
![]() 1860 forum posts 121 photos | these used to be common in the boating world. They are designed for short duration-high output used in straight running steam boats. |
File Handle | 21/11/2022 18:09:25 |
250 forum posts | Did get a second quick look today. Does look like a marine boiler that I found online. For example **LINK**
Vertical fire tubes go into a rectangular smoke box and chimney (both missing on one). |
