Dell | 23/09/2022 18:05:41 |
![]() 230 forum posts 44 photos | Hi all i have to make some small screws , a friend has measured one of his screws for me but the thread is odd , he said the thread I 1.2X0.3 but I can’t find that , a 13BA is 1.2X 0.25 and a metric M1.2 is 0.25 exactly the same so it’s possible that he has the pitch wrong ( possible with such a small screw ) or I haven’t been able to find it, so I thought I would ask the learned people on here, my BA set only goes to 12 BA but my small metric set goes from 1mm to 2.5mm so I tried a M1.2X0.25 in the threaded clock plate and the tap screws in although it’s very slightly loose. Dell |
DC31k | 23/09/2022 19:41:36 |
1186 forum posts 11 photos | Can the item in which the screw is to be inserted give any clues? Do you know where and when it was made? Are there any other fasteners on it that can be removed and measured? Have you considered M1.4 x 0.3 as a long shot? With something that small, you should ask how he has arrived at those dimensions (e.g. thread gauge and loupe for pitch, micrometer for major dia.) and use the answer to assess which of the two offers opportunity for error or confusion. |
old mart | 23/09/2022 20:05:00 |
4655 forum posts 304 photos | I would also favor M1.4 x 0.3, it is common for the actual threads to mic undersize slightly which can be misleading. |
Clive Foster | 23/09/2022 20:10:28 |
3630 forum posts 128 photos | Dell According to the incredible thread list produced by Andy Pugh :- No 12 Progress is 1.2 mm Ø by 0.3 mm pitch. Not a thread series I knew of or have encountered but a quick Google this link which includes a tabulation of sizes :- **LINK** https://www.sizes.com/tools/thread_progress.htm "A thread series used in watchmaking in Switzerland, 19ᵗʰ – 20ᵗʰ centuries. According to de Carle, “the most popular modern Swiss screw thread.” As is obvious from the table below, the size number is the diameter in tenths of a millimeter. Thread angle, 50 degrees; depth of thread, 0.8 pitch. Depth of rounding, 0.093 × pitch; radius, 0.0732 × pitch. The company sold ready-made screws, and issued a screw plate as a means of checking sizes. Much of the use of the series occurred when makers found it convenient to thread their own screws using the screwplate as a die." Clearly legit but possibly old enough to be obsolete and, presumably, screws may be unobtanium off the shelf. Clive Edited By Clive Foster on 23/09/2022 20:12:27 |
Martin Connelly | 23/09/2022 20:42:16 |
![]() 2549 forum posts 235 photos | Lowenherz Ø1.2 has a pitch of 0.25mm and a thread angle of 53°08" with flats on both root and crest. Since there are a lot of similar threads around this size it needs careful measurement to figure out the correct thread. What it is for and its origin may also help. I have had to make replacement Ø7 Lowenherz thread screws for a continental music box. Martin C |
Martin Connelly | 23/09/2022 20:45:04 |
![]() 2549 forum posts 235 photos | Should also add, Lowenherz Ø1.4 has a pitch of 0.3mm. Martin C Edited By Martin Connelly on 23/09/2022 20:46:40 |
Dell | 25/09/2022 11:00:58 |
Terryd | 25/09/2022 12:18:24 |
![]() 1946 forum posts 179 photos | Hi alI, hope that I'm not jijacking this thread, forgive me if I am. I need to know what threads are in the various bushes on a Stuart Turner 504 boiler. I'm not sure if the modern Stuart version has the same threads as the older ST one, perhaps someone could enlighten me? Best regards TerryD |
