out of practice grinding and having some issues
Another JohnS | 07/09/2022 14:06:27 |
842 forum posts 56 photos | I decided to grind up some HSS tool bits, 1/4" size. I dug through my box of HSS tooling, and found some 1/4" sq blanks, unground. I have not done much hand grinding in years, so maybe I'm just out of practice. (Carbide insert tooling, and not a lot of time in the workshop makes for lack of familiarity) I had trouble grinding them - I'm wondering if anyone can decode what these are? 6 off HSS Co5 4 off VASCO SUPREME 1 Dormer Sweden K520 1/4x21/2TB 12 I might have picked these up as a gift from a retired tool and die maker a few years ago. Anybody willing to give suggestions? Maybe I just need a pat on the back and a few words like "get on with it" |
Dave Halford | 07/09/2022 14:12:37 |
2536 forum posts 24 photos | Co5 is 5% Cobalt, so harder than normal HSS |
Clive Brown 1 | 07/09/2022 14:19:28 |
1050 forum posts 56 photos | Agreed, googling the Vasco and Dormer brands also show up as Cobalt HSS so will be quite hard. I find that a white grinding wheel does well on this type of toolsteel. |
Jeff Dayman | 07/09/2022 15:18:24 |
2356 forum posts 47 photos | Suggest using a coarse grit wheel to rough the shape. Also get a water container and keep it next to the grinder with room temperature water in it. A large tin can 400 to 500 ml size from the recycle bin (cleaned) will work great and won't melt if contacted by a hot part. Hold the workpiece in your fingers so you can feel it as it heats up. When it is uncomfortable dip the tool in the water and hold it there until cool. If you use this fingers / cooling method, the risk of overheating an HSS tool is minimal. It takes patience to grind HSS tools but once made they will last for ages. A very light touch up sharpening in a fine grit wheel will keep them cutting nicely. Some people like a whetstoned or honed edge but I don't bother with that generally, and get excellent finishes usually. |
Another JohnS | 07/09/2022 15:44:21 |
842 forum posts 56 photos | Thanks all - will go back at it now that I know it's just slow because of the hardness, but not impossible - looking forward to having these ground and in use. JohnS. |
Andrew Johnston | 07/09/2022 16:13:53 |
![]() 7061 forum posts 719 photos | I've never noticed much difference in hardness when grinding a wide range of HSS toolbits. I'd be surprised if the cold hardness varies by more than a few points on the Rc scale. Cobalt is added to increase hot hardness, at temperatures far above those at which one can hold the toolbit. When grinding HSS I have a water dip simply to cool the toolbit so I can hold it. The whole point of HSS is that it retains hardness at high temperatures. So, unlike straight carbon steels, it is unlikely to be annealed when hand grinding. After grinding a toolbit I give the cutting edges a lick with a diamond hone to remove any small burrs. If I need to remove a large amount of material I use the milling machine. A carbide cutter will mill HSS with no problem, like the involute shape on this 1/4" square HSS: Andrew |
mark costello 1 | 07/09/2022 19:59:41 |
![]() 800 forum posts 16 photos | A handy tip, when sharpening a tool bit or drill bit if You are not getting enough clearance on the bottom just move up higher on the wheel. I don;t use the tool rest. |
Ramon Wilson | 07/09/2022 20:50:38 |
![]() 1655 forum posts 617 photos | Not to disagree with Jeff (Dayman) but making a mild steel holder to take the HSS blank makes things so much easier to maintain the angles and position the tool blank especially when roughing the tool out initially. I finally made one after far too many scorched fingers. Just a hole big enough to take the diagonal dimension in a piece of round bar with a grub screw in the side is all that's required. Yes you do need to keep an eye on overheating but it's not a major concern with HSS as it is with home made carbon steel tools. Just a container of cold water beside the grinder is all that's required for that. I don't think I have ever spoilt the hardness of HSS of whatever grade by grinding temperatures and grinding new tools is something I approach with a degree of 'can I get by with something else' but when needs must a holder does take the pain out of the task.
Best - Tug |
Bill Davies 2 | 07/09/2022 21:10:19 |
357 forum posts 13 photos | So you have two choices - grind dry or (periodically) wet. If dry, then the 'temper' colours look unsightly, but unlikely to draw the temper. Retaining hardness at higher temperatures is the key feature of 'high speed steel' over the earlier plain carbon steels. Red heat is around the tempering temperature, so that's not forgivable, in spite of 'red hardness.' I find placing on the cold tool rest of the grinder takes out the excess heat quite quickly - I'm referring to smaller tool bit sizes. If wet, then cool frequently. Do not allow it to get very hot as the thermal shock can induce tiny cracks, reducing cutting tool edge life. Bill |
Nigel Graham 2 | 07/09/2022 21:16:43 |
3293 forum posts 112 photos | If I need remove a lot of metal from the blank sometimes I clear the bulk off with a cutting-disc on an angle-grinder. Yes, the tool does need clamping firmly! I do that outdoors to minimise hurling grit around a cramped workshop. It is speeds up the whole operation and saves wear on the bench-grinder wheels. Recently I needed grind a grooving and threading tool to make a tiny brass plug. I used a new 1/4" HSS bar to make a double-ended tool, and kept the top surface untouched to give both the required 0º top-rake and single height adjustment. |
Huub | 07/09/2022 22:27:37 |
220 forum posts 20 photos | I rough grind my tools by hand using the angle grinder. Finish the rough cutting by hand using the bench grinder (white stone). Finally I grind the tool using a diamond wheel (80 mm, € 5,-- version) using a holder having the right angle(s). Regrinding using this holder takes only seconds. I stack different holders to get the right angles. I do not grind the top of the tool. When using this diamond disk, I do not need to wed the cutting edges. Beware, HSS Co (cobalt) dust is toxic so use a good dust mask.
Edited By Huub on 07/09/2022 22:28:07 |
