Julian Tolley | 04/09/2022 15:53:17 |
11 forum posts 9 photos | I've had a Flexispeed large for years but recently a Simat 101 lathe cane available near me. I thought I would be able to mix and match but find the spindle is different (well the nose thread). So I now have to choose which one to get rid of. The Flexispeed uses oil for the main bearings while the Simat has grease filled fittings...not sure if they were a later feature or a modification. Anyone out there with experience of both.....and offer advice. |
peak4 | 04/09/2022 19:01:15 |
![]() 2207 forum posts 210 photos | My Simat is oil fed, rather than grease.
not done it yet | 04/09/2022 20:38:39 |
7517 forum posts 20 photos | Plain bearings generally need oil lube whereas rolling bearings (ball, taper roller or needle) can use either. Compare wheel bearings on vehicles - they can go for 100,000 miles without trouble.. |
Geoff Mathews | 07/09/2022 14:35:17 |
![]() 33 forum posts 6 photos | Some Flexispeed lathes - but not all - were serial numbered and had a hand finished bed - if your Flexispeed is one of these it might be worth keeping. |
SillyOldDuffer | 07/09/2022 17:14:55 |
10668 forum posts 2415 photos | The one that's in best condition! On paper the Simat looks like a refined Flexispeed, which is good, but not if the Simat's bearings have been damaged by being worked on grease. Buying second-hand we always risk being punished for the sins of previous owners! Dave |
