Metal Casting - Definitions
PatJ22/08/2022 18:24:36
613 forum posts
817 photos
Lets talk about definitions for metal casting, especially as related to hobby backyard castings for model engines, with a bit of preface.
I have seen some superb and basically flawless gray iron and aluminum model engine castings kit castings, and I have also seen casting kit castings in gray iron that were very expensive, but full of blow holes, and not really suitable for any engine use.
It seems to be accepted that castings with serious defects, and gray iron castings with chilled (very hard) spots in them are part and parcel to the hobby.
I am here to say that if I can make aluminum and gray iron castings without defects, and without hard spots, then everyone in the hobby should expect that the casting kit companies should also be able to do so when using "professional" foundries.
I have learned the metal casting hobby over the last 10 years, and I will share the secrets of making successful model engine castings.
But we need to discuss definitions first, and so the following:
Note that this is my slant on casting definitions, and perhaps not an exact thing.
1. Sprue: The sprue is the hole in which you pour your molten metal.
The sprue should be tapered, and should be small enough in diameter so as to fill quickly, and remain full at all times during the pour.
2. Pour basin: Many use a pour basin on the top of the mold, and they pour metal into the pour basin, which then overflows into the sprue.
Sometimes a basin is also used at the base of the sprue.
3. Runner(s): Runners are the horizontal passages that transmit the molten metal from the bottom of the sprue to the mold cavity. Runners are often V-shaped, probably since this makes it easy to withdraw the runner pattern from the sand mold. Runners are often located at the cope/drag interface, either in the cope, or in the drag. The cope is the top half of the sand mold, and the drag is the bottom half of the sand mold.
4. Gates: A gate is the passage or passages from the horizontal runner into the mold cavity. The purpose of a gate is to control the flow of metal into the mold cavity, introduce the molten metal into the mold cavity at the entry point(s) that you desire, and to skim the molten metal so as to catch any floating slag.
Gates can be many shapes, but are generally rectangular in shape, or sometimes a wide thin rectangle such as with a knife gate.
Knife gates are used when the casting is thin, such as with a plaque, and they allow the mold cavity to fill quickly across a wide area.
5. Riser: A riser is a chamber (void in the sand mold) located at strategic spots, with the intent of furnishing molten metal to a part of a casting while it is shrinking and soldifying. Often risers are used when the thickness of a casting is not uniform, so that you don't have the thin part of a casting solidify first, and draw metal from a thicker not-yet-solidified part of the casting; thus causing srhinkage defects and hot tears.
6. Hot Tear: A hot tear is what is sounds like. If part of a casting solidifies before the rest of the casting solidifies, it can create forces in the junction between these two areas, and the result is tears in the metal.
7. Inclusion: A n inclusion is something imbedded in the metal casting that is undesired, such as a piece of the sand mold, slag, etc.
8. Bubbles: Bubbles and similar round-edged defects in castings can be caused by absorption of hyrogen or other gasses in aluminum, too much water in the sand mold, resin molds that are not fully cured and flamed, or pockets of trapped air at the top of mold cavities that are not vented.
Bubbles can vary in size from very tiny pinhole size, to inches in diameter.
9. Spin trap: A spin trap can be used at the end of a runner, and it is a vertical shaft that often leads out the top of the mold. The purpose of a spin trap is to capture the initial debris that gets washed down the sprue and runner, capture any initial aspirated air that was mixed into the molten metal while the sprue was filling, and to prevent the molten metal from striking the end of the runner and splashing back into the mold cavity.
10. Cope: The top half of the sand mold.
11. Drag: The bottom half of the sand mold.
12. Flask: The wood or metal box into which the sand is rammed.
A flask often consists of two parts, which make the cope and drag molds.
PatJ22/08/2022 18:36:53
613 forum posts
817 photos
I have studied John Campbell's "10 Rules for Good Castings" for several years, and also studied the work of those who have successfully applied John's rules, in order to make flawless castings.
Some of the 10 rules are more critical on a hobby level than others.
Rule #1: Use quality scrap metal of a known composition.
I would add that you should use metal that will work well for the particular casting you are making, such as using bearing bronze for bearings, instead of some metal that has a very high stiction (don't ask me how I know this).
Velocity:
Probably the most critical thing in metal castings is controlling the velocity of the metal as it travels down the sprue, through the runner(s), through the gate(s), and into the mold cavity.
If you don't control your metal velocity, you basically get something similar to what happens with waves breaking on the shore. The metal folds over on itself like a wave, and then churns sand, air, slag, etc. into the molten metal. Churring/folding the metal as it flows should be avoided at all cost.
Metal velocity can be controlled several ways.
Some use the sprue as a choke to limit the metal flow rate.
Some use the gates to control the flow rate.
Some use ceramic sponge filters located either at the base of the sprue, or inline with the runner, to control flow rate.
I use the gates to control metal flow.
Mold Fill Rate:
The mold cavity should be filled as fast as possible, but not so fast that you cause splashing or turbulence of the molten metal.
You are basically looking for a laminar flow of the metal, where the wavefront of the molten metal as it travels down the runner and through the gates is never broken.
PatJ22/08/2022 18:39:16
613 forum posts
817 photos
One of John Campbell's rules is avoid waterfalling the metal into the mold.
If you have a tall mold, you should not introduce metal into the mold cavity in a way that causes the metal to run a long distance down vertically to the bottom of the mold cavity.
PatJ22/08/2022 18:42:18
613 forum posts
817 photos
Try to make the thickness of your casting consistent and constant.
If you look at sections of the old steam engine cylinders, you will see that almost every part of the cylinder has the same wall thickness.
You get even solidification when you use a constant casting thickness, without hot tears.
If you can't avoid using uneven casting thicknesses, you should consider using one or more risers, which allow you to avoid the small part of the casting solidifying first and drawing metal from the parts of the casting that are still molten.
PatJ22/08/2022 18:50:54
613 forum posts
817 photos
Where do the gate(s) go?
Gates are often used at the thickest part of the casting.
If you use gates at the thinner parts of the casting, the tendency is for the metal in the thin part to cool and solidify before the thicker parts of the casting have fully filled.
If possible, use gates at a part of the casting that has to be machined, so that the gate is eliminated after the machining work is complete.
For symmetrical castings (ie: somewhat square-shaped castings), I genrerally use one or two gates.
For long rectangular shaped castings, I often use multiple gates down the side of the casting, and often knive gates, which are gates that are wide and flat.
Try to locate gates on the casting where they can most easily be removed after casting, keeping the above in mind.
I use gates located at the top of the runner.
The idea behind the gates at the top of the runner is to allow the trash and aspirated air to flow down the runner to the end of the runner (ideally flowing into a spin trap).
The mold cavity does not begin to fill until the runner is completely full.
The gates provide one last skim of slag that may be floating on top of the molten metal.
If the gate is located at the bottom of the runner, all the trash is swept right into the mold cavity.
Edited By PatJ on 22/08/2022 19:10:43
PatJ22/08/2022 18:58:02
613 forum posts
817 photos
Vents:
There is some debate in backyard casting circles about venting a sand mold.
Some use sand that has enough permeability to allow the vents to be omitted.
I have had resin-bound molds trap large air bubbles at the top of the mold cavity, and so I always use vents at the high points of the mold cavity, in the cope or top half of the mold.
I make vents using a 1/16" diameter steel wire, which I poke from the interior of the mold out through the top of the mold.
I also vent my cores.
If my core is round, I normally make the core with a 1/4" wood dowel rod inside, and then withdraw the dowel, to leave a 1/4" passage through the core.
I use vertical vents from both ends of a core, 1/4" diameter, and these vents extend out the top of the mold.
I flame my cores lightly with a gentle propane flame.
Alternately, cores can be baked to drive off any residual moisture.
Many castings get ruined because the core was not vented or dried correctly.
PatJ22/08/2022 19:01:56
613 forum posts
817 photos
Traditional vs New Methods of Metal Castings:
John Campbell makes the point in his book that the traditional methods that have been used to make metal castings for many years are generally very bad methods, and should not be used.
After making my own castings using John Campbell's methods, and studying the castings made by others who use John Campbell's methods, I am convinced that John is right on this point.
Most of the traditional methods and sprue/runner/gate/riser methods should never be used, unless you want routinely defective castings.
PatJ22/08/2022 19:16:05
613 forum posts
817 photos
Pour Basin:
Pour basins are one of those things that have been used forever, and so it seems almost impossible to talk anyone out of using them.
I don't use a pour basin, but rather pour the metal directly down the sprue, with the crucible as close to the top of the sprue as practical.
You should fill the sprue as fast as possible to the top, and then keep the sprue completely full during the entire pour.  If you interrupt the pour before the mold cavity is completely filled, chances are you have aspirated air into the melt, and perhaps caused a cold joint inside the casting.
I use 1" section of 3" diameter heavy wall pipe above the sprue, and sometimes above riser openings.
The section of pipe acts like a pour basin to some extent, but also acts a a dam, to catch the metal when the mold gets completely filled, and to keep molten metal from running across the top of the mold.
The traditional pour basin is the base way I can think of to churn slag, air, and sand into the flow of metal, and ruin a casting.
People sometimes cling to their pour basins because "that is the way it has always been done".
And a lot of castings have defects too, but that is not a reason to keep making castings with defects.
Edited By PatJ on 22/08/2022 19:20:43
Nigel Graham 222/08/2022 19:17:37
3293 forum posts
112 photos
Thank you for a very comprehensive and lucid glossary and explanations, but I have a feeling that there are a few differences in US and UK terminology here.
For example, I'm pretty sure that every British text I have seen, calls the vertical inlet hole the Runner, the vertical outlet the Riser, and the passages connecting them to the mould cavity itself, the Gates*. While "sprue" would be the resulting sticks of metal from the gates and perhaps joining multiple casts together- a term extended to injection-mouldings of plastics as, e.g. in 'Airfix' kits. Their purposes in life are of course the same irrespective of name.
That said, yes, there is no reason why a trade foundry should not produce castings to the quality you expect and describe. While the amateur founder is certainly in with a good chance by following advice like yours.
I had looked into the subject but decided if I need castings, which would be very rarely, I would have them made, but would be happy to make the patterns.
*Odd point of etymology. Since the 'gate' in a mould is the metal's open route in, I wonder if this "Gate" is from the Norse word for street, not barrier, used in many names for thoroughfares in Northern English towns?
PatJ22/08/2022 19:26:25
613 forum posts
817 photos
Nigel-
I made a lot of bad castings before I got it figured out.
There is no reason for anyone to repeat all of my blunders, and so I am sharing what I know.
As for UK foundry terminology, I can't help with that.
I think John Campbell's book uses the terms that I use, and he is from the UK.
I have seen people pay good money for defective castings, and have done so myself.
All I can say is that castings defects are totally avoidable, both on the commercial and hobby levels, if one pays attention to details.
My castings don't have defects.
No gassing in aluminum castings.
No inclusions, hard spots, void, bubbles, chills, etc. in my gray iron castings, and very machinable gray iron castings.
I can help anyone trying to learn hobby casting, and save you a lot of headaches.
Edited By PatJ on 22/08/2022 19:26:57
PatJ22/08/2022 19:45:04
613 forum posts
817 photos
Backyard Casting "Mythbusters" of Youtube:
I have seen more than a few folks on youtube who "prove" that you can make quality metal castings by ignoring the fundamental rules for making quality castings.
In a hobby setting, which rules should be used?
There are no hard and fast answers; the methods and materials that you use should be the ones that work well for you.
I generally use a method or material consistently until I find a better more consistent or more reliable method.
If I am using a method, and it is working well, I don't change that method.
The problem with some youtubers is that they use a non-standard casting method, and pull off making a good casting, or perhaps what looks line a good casting from the exterior, and then use that as "proof" that you can make good castings using poor methods.
While it may be true that you can make a good casting using a poor method, it begs the question "Why not just use a better method if it is available".
I guess "better method" can be a bit objective.
What is a "good method"?
My definition of a good method is one that repeatedly and consistently create castings without defects.
My definition of a good method is also one that can easily be proven to be repeatedly effective, ie: section your castings and examine the interior for defects and consistency in casting thickness; drill the metal to test machinability, and break gray iron castings to look for a nice clean gray surface without chills (white spots).
Is there more than one "good method".
Yes indeed.
Are there a lot of bad (counterproductive) methods demonstrated on youtube?
Yes indeed.
Edited By PatJ on 22/08/2022 19:46:37
martin haysom22/08/2022 19:48:27
165 forum posts
Posted by PatJ on 22/08/2022 18:24:36:
the cost of [ almost ] defect free castings would most likely be more than the market would stand. i have spent most of my working life doing N.D.T on the very best casting available no such thing as defect free look close enough there is always something. I however will not comment on hobby castings as i have never used them
PatJ22/08/2022 22:11:22
613 forum posts
817 photos
John Campbell makes the arguement that the methods used in most foundries today do cause a lot of defects.
Others have show that if John Campbell's methods are adhered to, they can indeed make flawless castings, certified via xrays, scanning, etc.
The casting industry does not want to change their methods.
There are some very good new methods out there that have been proven to work well.
It does not cost any more to follow most (if not all) of John Campbell's methods.
But John's 10 rules for good castings may seem not that significant, they can make a huge difference in casting quality.
I think the problem with the castings made for this hobby (from what I have heard) is that they are often created at the end of a commercial foundry production run, and done in haste, without particular care.
The hobby casting business does not make enough money for the commercial foundries to bother with, and so most won't even consider them. Commercial founries are basically doing the hobby folks a favor.
I know from personal experience, and experience I have seen with others, that iron castings with a hardness of tool steel, and castings full of holes and inclusions are not really worth dealing with, unless you like to use a lot of JB weld.
The cost of the methods I use is not very much more expensive than any other foundry system.
I do use resin-bound sand, and ceramic mold coat, but the cost per castings on those items is not extreme.
I would guess the resin-bound and and ceramic mold coat, along with OK85 commercial sand probably add $6.00 per casting, but even if it added $12.00 per casting, that would be well worth it in my opinion to get high quality castings.
I have seen others get superb results in iron and aluminum with either green sand or Petrobond (oil-based sand).
PatJ22/08/2022 22:38:30
613 forum posts
817 photos
It should be noted that you can often cast a number of smaller castings in the same flask, and so the $6.00 per casting adder refers to castings that are so large that they take up an entire flask.
JasonB23/08/2022 07:12:14
Is that the real cost Pat?
You have said in another thread that the fumes from the resin are a problem and you need to use PPE. A commercial foundry would no doubt need to invest quite a bit for fume extraction and PPE for their employees even for the home caster spreading the cost of a respirator over the small number of castings they may do a year would up the cost.
You have also mentioned shelf life of some products, again hobby users may only do the odd casting and any materials will a shelf life will have gone off by the next batch so although you may only use a small amount of material on a single flask, if 50% gets thrown away then that will up costs.
I see you have a set of green twin castings in one of your albums which looks like it used resin bound sand which you say is the way to go but many faults in the castings there so what else have you changed since you poured those to get the perfect casting?
PatJ23/08/2022 08:31:30
613 forum posts
817 photos
Here are a few random responses to Jason's questions:
A commercial chemical respirator is perhaps $24.00, so no big deal.
A box of nitrile gloves is another $12.00.
Most commercial foundries use resin-bound sand of one variety or another, especially with ductile iron and steel castings. Resin bound sand with a ceramic mold coat makes an absolutely superb iron or steel casting.
My first order of resin binder was 5 years ago, and I am still using that product without problems.
The resin was difficult to find.
You really need to use a commercial foundry sand such as OK85 if you use a resin binder.
Bound sand is not easily recyclable, but you can get very significant casting improvements using bound sand.
Bound sand molds harden, and so you can use a far thinner and lighter mold than with green sand, so my resin-bound molds can be perhaps 30% the size of a greensand mold for the same part.
One less expensive alternative to resin-bound sand is sodium silicate bound sand, which is suppose to work well even with iron. I have used sodium silicate with some molds, but more with cores.
The best way to use sodium silicate as a binder is to use a catalyst, so that it hardens without CO2.
If you can't find the catalyst, you can harden sodium silicate bound sand with CO2, but don't over gas it (5 second gas only).
Sodium silicate does not have the problems as far as chemical exposure that resin-bound sand has.
I looked back in my albums, and you are correct about there being a lot of casting defects with my resin-bound sand molds.
The photos I took in 2012 show all sorts of casting defects, when I used resin-bound sand.
The difference between then and now is that in 2012, I had absolutely no idea what I was doing as far as foundry work, other than pressing a pattern in sand, and then attempting to get iron hot enough to pour into it.
In 2012, I was like a blind man stumbling through the forest, trying to find his way, and hoping for good luck, and ditto when I was trying to learn 3D modeling.
I did not know how to tune a burner so that I could reach a good iron pour temperature, and I did not have a clue about the correct sprue/runner/gate/riser configuration.
Fast foward 10 years, and have studied John Campbell's methods, read many many casting books, watched endless casting videos, etc.
I have now use a much lighter mass furnace now, which fires much faster and reaches iron pour temperatures quicker.
I am now very familiar with how to optimize the temperature of an oil burner.
I know now how to do sprues/runner/gates/spin traps, vents, risers, etc. in a repeatable and consistent way.
In 2012, I was lucky to get any type of casting at all.
Today, I can lay out a flask, pour a part in gray iron, and pretty much guarantee anyone that the part will be easily machinable, with no inclusions, hard spots, voids, bubbles, or any other defects.
People have said "I don't believe you can consistently make very high quality gray iron castings".
My response has been "Come over to my house, bring some patterns, and we will make some iron castings. You will very quickly become a believer". So far nobody wants to see it for themselves.
Talk is cheap, but throwing some high quality iron castings on the table pretty much speaks for itself.
I can match or exceed the quality of commerical grade iron castings easily, and repeatedly, but it took 10 years to learn the tricks.
Yes, that is the real cost.
Prices have been skyrocketing this year, and so you can be generous and say that using resin bound sand adds perhaps $12.00 per flask.
I see people "saving money" by using greensand, and often the have to re-cast a casting more than once to get it right.
Compared with the time spent trying to correct a bad casting, $12.00 per flask is very cheap in my opinion.
You have to factor in the cost of mis-casts that you get when using less reliable methods and sand/binders.
I can't remember the last time I had to recast anything; it just does not happen these days with me.
I have basically made every conceivable mistake that can be made in casting metal, and now I know exactly what to do, and more importantly what not to do.
The slurry that is used for lost-was and lost-PLA castings does appear to have a pretty short life, perhaps 1 year, and you cannot let that material freeze.
I am not trying to toot my own horn, but I do have the gray iron casting thing down very well, and while setting up a home foundry may a bit pricey, stepping up from greensand to resin-bound sand is about $12.00 per flask, best I can tell, and that is on a hobby level.
Edited By PatJ on 23/08/2022 08:39:27
PatJ23/08/2022 09:15:42
613 forum posts
817 photos
My sources of foundry infomation include a subscription to "Modern Casting" magazine, white papers about how to convert from weldments to to ductile iron castings, and case studies on the best approach to casting various parts in different metals, using different sprue/gate/runner/riser configurations.
Another source are the videos on youtube about mold fill simulations.
The mold fill simulations allow you to see the results of excessive metal velocity, and accompanying splashing and churing of the molten meltal in the runners and mold cavity.
Solidification simulations allow you to diagnose how a part will solidify, so you can avoid things like hot tears and shrinkage.
I will try to find some links to the better white papers and videos that I have found.
Edited By PatJ on 23/08/2022 09:16:47
PatJ23/08/2022 09:20:44
613 forum posts
817 photos
Here is a great example of why many castings have so many defects from excessive velocity and poorly placed gates.
https://www.youtube.com/watch?v=sZUGgaa0oUw
PatJ23/08/2022 09:35:42
613 forum posts
817 photos
This one is for die casting a cylinder, but still some useful information to be gained from this video.
https://www.youtube.com/watch?v=xzAVeiz_A2I
PatJ23/08/2022 09:37:11
613 forum posts
817 photos
Crankshaft fill simulation.
https://www.youtube.com/watch?v=JXkKYAQ1rXs
