wiring a Charlatan
Boldminer20/08/2022 04:11:44
41 forum posts
13 photos
I am now ready to wire up my charlatan but not being schooled in electrickery I am completely overwelmed by the the information supplied to me by 4QD who supplied all of the components required for the job. Is there anyone out there that can point me in the right direction or supply a definitive step by step guide to completing the the wiring
Many thanks
Emgee20/08/2022 10:23:06
2610 forum posts
312 photos
A good starting point for help would be a view of the schematic provided by 4QD and a picture of the parts in the kit.
Emgee
noel shelley20/08/2022 10:27:04
2308 forum posts
33 photos
Give us the info and someone on here will be able to help. It should be fairly straight forward. Noel
Boldminer21/08/2022 05:45:07
41 forum posts
13 photos
Emgee and Noel, thank you for you promt replies/responses. Noel if you will give me a little time to colate the information I need I will message you with/for the help and information I require.
Rgards, Colin (Boldminer)
Jon Lawes21/08/2022 15:56:58
1078 forum posts
Roughly where in the country are you? I'd be happy to give some guidance if local.
Boldminer23/08/2022 01:56:19
41 forum posts
13 photos
Hello Jon, what a wonderful offer,and if it were at all possible I would love to take you up on your offer of a visit. However as I live in Phuket,Thailand I cant see you being able to make it back home in time for tea although you would be made more than welcome welcome if you did come. Seriously though Jon I really do appreciate your response to my plea for help and even more so your very kind offer of a home visit. So inbetween domestic duties I intend to once again study the information supplied by 4QD to see if and where I need more guidance in order to be able to ask the relevent questions about the electrical installations.
Regards, Colin
Boldminer24/08/2022 08:54:35
41 forum posts
13 photos
To all that were kind enough to respond to my plea for help, I have studied and restudied the information supplied by 4QD and on their web site but find there are a few areas where I still would appreciate a little help if you could be so kind............ My understanding and assumptions are as follows :-
1) If I am using 2 x12v batteries then the lead that connects the two together is broken by the main isolator that is placed conveniently at the rear of the cab.
2) A lead is taken from the negative terminal on the first battery to the terminal B- on the control unit with another lead from the same battery terminal going to the connection marked 4NC on the HRB wiring diagram.
3) The positive terminal on the other battery is wired directly to terminal 4NO on the HRB diagram.
4) A second wire from the positive terminal on the first battery is taken to terminal 3NO on the HRB board via an auxillary fuse.
5) The wiring for the horns is from connections 1NC and 1CO plus 2NC and 2NO respectively on the HRB board. Would I need to fit what I think are the catching diodes to these connections using connector blocks or are they fitted to the terminals on the horns themselves ?
6) Regarding the motors ( I am running 4 ) do I literally join all the 'positve' and all the 'negative' wires together in order to connect them to the single terminals on the DNO control unit, and at what point would they be joined? Am I OK to run the twisted motor wires alongside each other along the chassis to the controller?
7) Included with the noise suppresion kit is a red transient suppressor, do I need to fit this and if so do I simply fit it using a connector block?
8) Batteries.... can you recomend suitable batteries and would a simple trickle charging system be OK to keep the batteries charged?
I look forward to you replies and comments in order that I can complete the loco for my Thai grandson to use on the 5" track that I have constructed.
Appreciatively, Colin
0
