Nick Welburn | 30/07/2022 20:14:20 |
136 forum posts | The heads of the tappet screws on my VW baywindow with hydraulic lifters are some what hammered and won’t easily adjust. |
Speedy Builder5 | 30/07/2022 20:23:22 |
2878 forum posts 248 photos | Are the tops soft ? Maybe get away with a carbide tool ?? |
Robert Butler | 30/07/2022 20:25:22 |
511 forum posts 6 photos | 8 x £5 = £40, why bother? Robert Butler |
Nick Welburn | 30/07/2022 20:52:32 |
136 forum posts | Posted by Robert Butler on 30/07/2022 20:25:22:
8 x £5 = £40, why bother? Robert Butler Well mostly because 8 x £5 = £40. I’ll have a play suspect I’ll end up ordering a set |
noel shelley | 30/07/2022 23:19:59 |
2308 forum posts 33 photos | I would expect them to be hardened ! Noel |
Hopper | 31/07/2022 02:07:00 |
![]() 7881 forum posts 397 photos | Yes they will be hardened. Maybe spin and dress with a diamond file? But if they are case hardened, you might go through the hard layer to the soft material below if too much metal is removed. |
Dave Halford | 31/07/2022 09:14:16 |
2536 forum posts 24 photos | Hydraulic lifters (cam followers) are self adjusting, unless they have collapsed and are therefore noisy in which case you buy new lifters. |
Nick Welburn | 31/07/2022 09:21:45 |
136 forum posts | Posted by Dave Halford on 31/07/2022 09:14:16:
Hydraulic lifters (cam followers) are self adjusting, unless they have collapsed and are therefore noisy in which case you buy new lifters. Hi Dave, They generally are, and VW described them as such. The reality is though they need a tickle here and there. I had one that had unwound so I’ve started a reset. From what I’ve found they seem to have had a hard life and I can’t get the preload on as they slide off the valve tip from the wear (hammer!) patterns |
Dave Halford | 31/07/2022 15:39:18 |
2536 forum posts 24 photos | Nick, Is the rocket arm wobbly then? It should be impossible to slide off the valve stem unless either the rocker or rocker shaft has a lot of wear. |
Nick Welburn | 31/07/2022 15:41:47 |
136 forum posts | Posted by Dave Halford on 31/07/2022 15:39:18:
Nick, Is the rocket arm wobbly then? It should be impossible to slide off the valve stem unless either the rocker or rocker shaft has a lot of wear. It’s lightly spring loaded to hold position on the rocker arm. Because the tip is chewed up it’s pushing the rocker across as you preload it. Hence the desire to clean it up. |
Dave Halford | 31/07/2022 15:47:02 |
2536 forum posts 24 photos | These are go faster parts, but the write up does illustrate the problem. |
Nick Welburn | 31/07/2022 15:50:50 |
136 forum posts | Interesting, mines a type 4 2.0l but I suspect the issue is the same |
Hopper | 01/08/2022 04:40:33 |
![]() 7881 forum posts 397 photos | At 20 Quid for a set of 8 adjuster screws from the Cool Air VW Specialists website I think I would just buy new ones. In fact I would pay the 40 Quid and get the elephant foot type with the captive ball bearing with a flat ground on it. |
mgnbuk | 01/08/2022 16:09:00 |
1394 forum posts 103 photos | Do away with the problem completely - put a Subaru engine in it ! Nigel B. |
