Emco Unimat motor tripping RCD
David T17/07/2022 17:57:59
76 forum posts
14 photos
Hi everyone,
SWMBO has just bought herself an Emco Unimat SL1000. The trouble is, the motor is tripping the RCD. It is not tripping instantly, so it’s not the in-rush, but it trips after 2-3 minutes of running. By the time the RCD trips the motor is warm to the touch, even running no-load. The trip is bypassing the circuit MCB and hitting the master RCD, so it’s a leakage not an overload.
The motor is a 70W, 240v single phase brushed motor. I’ve dismantled the motor and cannot see any obvious faults in the wiring. Using a multimeter I’ve found there is good continuity between the Earth pin and the casing, and open-circuit between Earth and live / neutral (I have no means of doing a proper insulation test of the windings). I’ve tested the motor in two different sheds (so two different RCDs), and with everything else unplugged to rule out the combined effect of a secondary leakage.
Can anyone offer any advice please?
Thanks
John Rudd17/07/2022 22:47:53
1479 forum posts
Does the lathe have a speed controller fitted to it?
If so, disconnect the motor from the controller, then check see if the rcd trips…that will rule out the motor…
report back your findings, we’ll go from there..
Dave Wootton18/07/2022 06:12:43
505 forum posts
99 photos
As these are all quite a few years old there is a known problem with the suppression capacitor deteriorating, if you look on the Lathes.co.uk website there is a page devoted to the motor capacitor change with diagrams. I had a look ast one of these for someone a while ago and it was doing a similar thing, tripping after about thirty seconds,although the motor did not seem unduly warm after that short time, got a new capacitor as mentioned in the article from Maplins. I know Maplins have gone now but someone must sell an equivalent, the lathe is still working now I believe.
The replacement capacitor is larger and will not fit in the motor casing, it was put in a small plastic box with a toggle switch to replace the original inline switch.
Edited By Dave Wootton on 18/07/2022 06:17:12
John Haine18/07/2022 06:17:14
5563 forum posts
322 photos
Easy thing to try, just remove the capacitor. If it runs ok you have found the problem. New cap available from eg RS or Darnell, cheap as chips. No problem to run briefly without.
Michael Gilligan18/07/2022 06:33:57
23121 forum posts
1360 photos
Posted by David T on 17/07/2022 17:57:59:
[…] but it trips after 2-3 minutes of running. By the time the RCD trips the motor is warm to the touch, even running no-load. […]
It doesn’t really make it any easier, but that would seem to suggest that the leakage only occurs when the motor is warm. … Ergo, you have a fault which causes the motor to heat-up, and an effect of leakage to Earth
So … simple bench-tests on a cold motor are unlikely to identify the fault sad
Edit: __ as John suggests, the culprit might very well be the capacitor.
Edited By Michael Gilligan on 18/07/2022 06:36:13
Brian G18/07/2022 09:27:12
912 forum posts
40 photos
Mine did the same thing, I followed the instructions on lathes.co.uk and fitted a capacitor (and a switch) in an external box.
Link to lathes.co,uk
Brian G
David T18/07/2022 15:33:43
76 forum posts
14 photos
Posted by John Rudd on 17/07/2022 22:47:53:
There is no speed controller fitted.
Thanks all for the replies, I will try the capacitor as suggested and go from there
