Unidentified tool.
Douglas Carse | 05/07/2022 12:43:30 |
4 forum posts 8 photos | What is this for? Inherited in a box with various other lathe tooling. Approx 100mm long, with the two parts of different diameters rotating around a central axis. Indexed at six positions by a ball/spring inside. An index thing of some type, but how/where would it be mounted, and what could it be used for? |
Phil P | 05/07/2022 12:59:29 |
851 forum posts 206 photos | Looks like a lathe carriage stop to me. Phil |
Tony Pratt 1 | 05/07/2022 12:59:33 |
2319 forum posts 13 photos | Six position indexable stop. Tony |
Nigel Graham 2 | 05/07/2022 13:25:56 |
3293 forum posts 112 photos | An indexing stop like this is for producing repetition work, and from time to time designs directly or adaptable for Myford, Warco, Boxford etc lathes appear in the model-engineering literature. Industrially they were typically fitted to capstan lathes but can be used on conventional ones as well. The mounting would vary from machine to machine, but typically the rotating part is on the headstock side of the saddle, and its adjustable screw-heads stop at a block whose own position is itself adjustable, along a bar mounted on the bed somewhere between the front shears and the lead-screw or feed shaft. On a full repetition-lathe I would expect the stop to be indexed by the capstan or turret. A similar stop is used on turret-type bench drills, though built into the head and indexed by the turret's own stepping. This one might be from such a machine. It looks as if the previous owner had obtained this specimen incomplete and second-hand somewhere, and has had to improvise a bit, judging by that long screw with a rivet-bush on it! Edited By Nigel Graham 2 on 05/07/2022 13:26:32 |
