GeoffT | 04/07/2022 15:38:21 |
30 forum posts 11 photos | Hi all Am currently building Elmer Verberg's VR75 vertical engine. On the cylinder body the two ports are shown as 1/16" x 5/8". This seems too wide, I think it should be 1/16" x 3/8". Anyone else built this engine and can confirm the size? Thanks GeoffT |
Martin Connelly | 04/07/2022 16:22:11 |
![]() 2549 forum posts 235 photos | The drawings I have show two ports of 1/8 x 5/8 and a central exhaust port with three 1/16 holes at 3/32 spacings. Looking at the valve it has a central recess 1/4 x 9/32 and outside dimensions of 13/32 x 7/16. This seems odd until you see that there is a valve plate that goes between the cylinder and the valve and that has got 9 x 1/16 holes at 3/32 spacing. I think the dimension on the drawings I have look as though they will work out fine. Martin C Edited By Martin Connelly on 04/07/2022 16:27:44 |
JasonB | 04/07/2022 16:31:01 |
![]() 25215 forum posts 3105 photos 1 articles | They don't really need to be any wider than the overall width of the sets of 3 holes in the valve plate, I'd probably still use an 1/8" cutter as it's a bit more robust than 1/16" Probably meant to read 5/16 wihich gives a bit to play with over the holes which would total 1/4" The 5/8" is clearly wrong when compared to the 3/4" dimension for the valve chest studs Edited By JasonB on 04/07/2022 16:31:53 |
Martin Connelly | 04/07/2022 16:34:46 |
I also think it should be 5/16 not 5/8. The outer dimension of the 1/16 holes and the 3/32 spacings is 1/4" This is slightly less than 5/16 so there is a bit of leeway in the cylinder ports allowing for some mismatch between the cylinder and the valve plate. Martin C Edited By Martin Connelly on 04/07/2022 16:40:13 Edited By Martin Connelly on 04/07/2022 16:41:12 |
GeoffT | 04/07/2022 17:02:05 |
30 forum posts 11 photos | Thanks Jason and Martin, that seems to make sense. 5/16" it is, also will probably go with 1/8" cutter as per Jason's suggestion. GeoffT |
