Alan Donovan | 01/07/2022 16:53:26 |
81 forum posts 41 photos | Hi all. I believe I have a faulty Neutral switch on a Yamaha FZ 750. Replacement part plus new seal are now ready to be fitted, but its location on the bike is not obvious. Close inspection of the bike and scouring thought the parts manual, I have come to the conclusion that it is located behind the drive sprocket cover. This cover also supports the hydraulic piston for the clutch (this appears to push on the end of a long rod that actuates the clutch) and also the gear change shaft passes through this cover. I intend (hope) to remove the sprocket cover with the clutch piston assembly still attached ....... it seems possible. Before I go 'blundering on' I thought I would ask for a 'sanity check' and ask if there is anything I should be aware of, or take particular care about. Please find below parts diagram for neutral switch (item 6) and a photo of the cover I intend to remove.
Many thanks in advance to all who respond. Best regards. Alan. |
bernard towers | 01/07/2022 17:45:56 |
1221 forum posts 161 photos | looks very much like a modified disc brake calliper which should mean its self contained, you should be able to unbolt and remove with no fluid loss (I hope). We did a similar thing in the 70s to make the clutch hydraulic on A65s.I would imagine once removed neutral switch will appear!. |
DiogenesII | 01/07/2022 18:14:11 |
859 forum posts 268 photos | Yes, what BT said, you should be able to take it all off still attached, hang it up on a bungee or similar - it's not best practise to let it hang from the pipework which can strain pipe / union. If you do need to remove the actuator first, leave it attached to the hose and it will come out 'dry' and can be moved out of the way. Just refit it, no adjustments or 'special measures' required. You should check in the 'window' to see whether you will need to DRAIN THE OIL BEFORE REMOVING THE SWITCH - the business end is in the 'wet' side of the gearbox. Be mindful to ensure the O ring on the new switch seats correctly and doesn't get pinched or twisted on assembly - a smear of oil may help. Check everything works as expected before taking it out !
Hopper | 01/07/2022 22:46:39 |
![]() 7881 forum posts 397 photos | Looks very similar to my VFR800 Honda. You can pull the clutch actuator or the whole cover off with the hydraulic hose still attached and swing it to one side and tie it up with a bungee cord etc. The hydraulic unit is self contained, with a thrust bearing built into the piston and the clutch pushrod, which stays in the hole in the middle of the sprocket shaft, locates in a dimple in the end. So the piston unit is free to simply move away as required. It pays to flush fresh fluid through the unit from the mastercylinder every two years to prevent corrosion and gumming up. |
