mechanical edge finder - amount of movement
Y C Lui01/07/2022 13:23:33
84 forum posts
35 photos
I noticed that the amount of movement of my edge finder upon contact has been reducing over time. Just wondering what the possible causes are. I have been using it to locate the corner of my vice only and that part of the vice has now become more shiny due to repeated rubbing by the finder. Can the increased smoothness of the surface be the reason ?
SillyOldDuffer01/07/2022 14:06:44
10668 forum posts
2415 photos
I'm impressed by anyone who works a mill hard enough to polish the vice with an edge-finder!
I doubt the smoothness is the cause though. Assuming the finder is one of this type, photo filched from Arc Euro:
The bottom half of the finder is free to float relative to the top except for a light spring that keeps the two halves from falling apart. When the finder is spun by the mill, the lower part is first nudged into alignment with the spindle's axis; the balance is both accurate and delicate. When the lower surface of the finder touches an edge, it flies off the axis. How far it goes is restrained by the spring.
As the spring is unlikely to change much, I suspect dirt has got inside and is restricting it's travel. On my finder the lower part can be pulled down far enough to allow in a squirt of WM40 or similar, which should dislodge any muck inside.
Bo'sun01/07/2022 17:39:09
754 forum posts
The amount of "kick" you see can vary depending on the viewing position. Are you viewing it from a different position?
Dr_GMJN01/07/2022 17:41:37
1602 forum posts
I found that using WD40 to clean mine caused stiction. Ended up separating the faces with a cocktail stick and firing brake cleaner into it. Once it evaporated, it was fine.
