Boxford Model C lathe change gear cover
Method of attachment
AJAX29/06/2022 17:48:38
433 forum posts
42 photos
Could someone with a Boxford Model C lathe post some photos showing how their change gear cover is attached to the lathe? I have the lathe and end cover, but the lathe came to me partly dismantled with no clear method of fixing the cover to the headstock. There are a couple of screw holes but no sign of a hinge or bracket to hold the cover in position. I'm guessing it was screwed into position with a fixed bracket or two (now missing), which would have made gear changes very inconvenient. I'm quite open to fabricating an entirely new / non-original arrangement if it improves on the original design.
Clive Brown 129/06/2022 18:49:37
1050 forum posts
56 photos
The cover on my ME10 is hinged on an arm that clamps on the rear shear of the bed.A peg on the cover fits into a hole at the end of the arm, allowing the cover to swing. The arm's slightly curved. Hope that helps.p1030100.jpg
Grindstone Cowboy29/06/2022 20:01:49
1160 forum posts
73 photos
Can't get any photos of my Model C just at the moment, but it's the same as Clive's ME10. Held shut by a screw and knurled knob at the front.
Rob
Dave Halford29/06/2022 20:04:42
2536 forum posts
24 photos
Busted and thrown away.
Nicholas Farr29/06/2022 20:05:30
3988 forum posts
1799 photos
Hi, my Boxford CUD just has a piano hinge.
Regards Nick.
AJAX29/06/2022 20:14:56
433 forum posts
42 photos
Posted by Clive Brown 1 on 29/06/2022 18:49:37:
Thanks for the photo, Clive. I hadn't considered clamping anything there. And by the look of it, the cover must be hinged elsewhere to support the swinging weight?
AJAX29/06/2022 20:17:00
433 forum posts
42 photos
Posted by Nicholas Farr on 29/06/2022 20:05:30:
Regards Nick.
That would be my preferred option but there is no obvious place to mount such a hinge on my model c. Maybe I need to fit a plate to the outboard end of the headstock first.
AJAX29/06/2022 20:17:34
433 forum posts
42 photos
Posted by Dave Halford on 29/06/2022 20:04:42:
The hinge or cover?
Clive Brown 129/06/2022 21:37:14
1050 forum posts
56 photos
Posted by AJAX on 29/06/2022 20:14:56:
No, the pivot at the rear end of the arm takes the full weight of the cover when it is swung open. A knurled screw, as mentioned by Rob, holds it firmly when closed.
Hopper30/06/2022 02:54:06
7881 forum posts
397 photos
Posted by Clive Brown 1 on 29/06/2022 21:37:14:
That looks much the same as the original South Bend hinge, and its Aussie clone the Hercus. Kind of a jury-rigged afterthought look to it, but they seem to work ok. Bit awkward to fabricate though. And I suppose shipping a South Bend item from the US would cost as much as the part itself these days (about US$60)
