Wal Werbel | 11/05/2022 14:44:43 |
![]() 40 forum posts 34 photos | Hello all, Having recently made a couple of brass signs (pics below) I'm wondering about how to seal - or even whether or not to bother. My options so far are
I'm already using shellac to seal in the patina and I'm gravitating towards wax for the bare metal bits - my reasoning being that it's non-permanent and will allow for easier maintenance - ie. not having to remove lacquer once it crazes and the brass below starts to blacken. Any opinions and further tips? Many thanks. Wal. |
noel shelley | 11/05/2022 16:14:02 |
2308 forum posts 33 photos | DO NOT laquer ! Unless extreme care is used the lacquer WILL NOT adhere to a polished surface and VERY easily chip with handeling. There is not prize for guessing how I know this ! The No 9 is brass the other looks more like a bronze ? Noel. |
bernard towers | 11/05/2022 17:39:39 |
1221 forum posts 161 photos | Microscope makers used to lacquer their instruments successfully why not use whatever they used (shellac based I believe). Personally I use Halfords clear lacquer and have never had it craze (so far). |
Mike Crossfield | 11/05/2022 18:08:48 |
286 forum posts 36 photos | If, as seems likely, the items are going to be exposed to the weather, the only real solution is lacquer. I can recommend Incralac. This was developed specifically for copper based alloys. A bit pricey, but good stuff. Available in tins or aerosol cans. Mike |
Grindstone Cowboy | 11/05/2022 19:42:40 |
1160 forum posts 73 photos | I believe you can get clear powder coating - that might be an option? Rob |
Jon Lawes | 11/05/2022 20:44:21 |
![]() 1078 forum posts | We used Incralac for brass letters on the stern of a boat; they have retained their polish nicely with no sign of cracking or crazing yet, and its been on there longer than I can remember. |
Wal Werbel | 12/05/2022 02:40:20 |
![]() 40 forum posts 34 photos | Incralac it is, then. Many thanks for your advice! Wal. |
Kiwi Bloke | 12/05/2022 08:39:31 |
912 forum posts 3 photos | Wal, lovely work! Please could you tell us how you made these? Presumably not cast, as traditionally done (?). [Edit} Oh, just seen your other post. Presumably similar technique... Edited By Kiwi Bloke on 12/05/2022 08:42:53 |
Wal Werbel | 12/05/2022 10:51:37 |
![]() 40 forum posts 34 photos | Posted by Kiwi Bloke on 12/05/2022 08:39:31:
Wal, lovely work! Please could you tell us how you made these? Presumably not cast, as traditionally done (?). [Edit} Oh, just seen your other post. Presumably similar technique... Edited By Kiwi Bloke on 12/05/2022 08:42:53 Kiwi, this technique is achieved using the 'texture' tool-path in VCarve. It's pretty cool but it takes an age to machine - less detail and bigger tools speed it up a bit, but there's a lot of up down, move a bit, up down, move a bit etc. Fine for one-offs, but certainly not a production technique, for example - the texture on the Church Villa sign took around 6-7 hours..! On my other post (the badge) the texture is modelled and machined with a 0.7mm ball-nose end-mill. Wal. |
