Greensands | 24/04/2022 12:49:43 |
449 forum posts 72 photos | I use AutoCad 2000 which is more than adequate for my purposes for producing workshop drawings but I do find it annoying that almost after every modification there is a need to regenerate the image ((View/Regen) in order to clean up the display. Is there something which can be done to minimise the need to do this? |
Robin | 24/04/2022 14:49:34 |
![]() 678 forum posts | Do you have REGENAUTO set to ON? This may or may not help, on a hard zoom my circles still become octogons until I give it a manual REGEN
PatJ | 24/04/2022 15:04:18 |
![]() 613 forum posts 817 photos | I use AutoCad 2004, and am running into the same issues. For smaller files, this was not a problem, and only took a second or so for a regen, which I have on a keyboard shortcut key. For my current project, I have perhaps 100 drawings in one file, which is about 8MB, and the regens have become longer than I would like, along the lines of perhaps 20 seconds. People have said "Don't put all your drawings in one file", but the efficiency of cut-and-paste, and the quick access to all areas of the design make it the only efficient way to do the project. I am having to purchase a new computer, with hopes that the problem will be minimized. I bought an HP desktop, 32GB ram, 6GB ram on the video card. I hope this computer works, since I have a lot of money riding on this project. One thing I have found that helps is running the purge command repeatedly until the file is cleaned up. I have found that this can reduce a file size from 10 MB to perhaps 6 MB. . Edited By PatJ on 24/04/2022 15:04:53 |
Paul Lousick | 25/04/2022 14:02:05 |
2276 forum posts 801 photos | In the early versions of Autocad, when working with large drawings it is better to make the value of REGENMODE system variable to 0 to improve the performance by avoiding unnecessary automatic regenerations. But you will have to do a manual regen after zooming, etc. The default value is set to 1 which allows unnecessary regeneration in drawings and may deteriorating performance. |
