bricky | 23/04/2022 11:55:45 |
627 forum posts 72 photos | Following the debacle over the jiggered lathe I am trying to remove the arbours but with little success I don't know wether they are right or left hand threaded and there is little to get hold of .Has anyone had to remove these arbours,if so I need suggestions as they have been soaking in WD40 for two days and I can't shift them. Frank |
Hopper | 23/04/2022 12:15:49 |
![]() 7881 forum posts 397 photos | They have locknuts on the back of them. You have to take off the main tumbler output gear, after removing the small screw and washer in the middle of it. Then pull the whole tumbler reverse lever assembly off the stud it pivots on. Then you can get at the two 1/4 BSF hex nuts on the back of the reverse lever, one on the end of each Tufnol gear's stud. Undo those nuts, the normal right hand thread way, ie counterclockwise. Studs should then come straight out. Assuming its an ML7. If it's a Super 7, I have no experience, but it looks like the studs are a press fit. So you take the whole lever assembly off and press them out from behind. (Press being the technical term for whack with a hammer and brass drift while supporting the gear on a suitable round thing.) No unscrewing involved by the looks. To get the lever assembly off, it looks like you have to undo a grub screw somewhere in the headstock to let the pivot stud out. Once you remove the old gears and install the new ones, when you press the studs back in, you will have to make sure to leave a bit of end clearance so the gears don't bind. Five or ten thou should do it.
Edited By Hopper on 23/04/2022 12:31:55 Edited By Hopper on 23/04/2022 12:36:27 Edited By Hopper on 23/04/2022 12:45:33 |
Swarf, Mostly! | 23/04/2022 12:19:07 |
753 forum posts 80 photos | Hi there, Bricky, Why do you need to remove the arbors? If you look at the illustrated parts list (aka 'exploded diagram' ) which is downloadable from the Myford web-site, the arbors appear to be an interference fit, not threaded. So you'd need to press them out. The illuatrated parts list is here: exploded diagram Best regards, Swarf, Mostly! Edited By Swarf, Mostly! on 23/04/2022 12:21:02 |
Swarf, Mostly! | 23/04/2022 12:27:33 |
753 forum posts 80 photos | OOps!!! I defer to Hopper, I misread the exploded diagram (I've never had to take my arbors out). The bit I thought was the interference fit, I now see is the part on which the gears run. I still wonder why Bricky wants to take them out? Best regards, Swarf, Mostly! |
Rod Renshaw | 23/04/2022 12:29:15 |
438 forum posts 2 photos | It seem possible that different models of Myford, and perhaps different years of manufacture, have different methods of fixing so need to check. By the way, WD40 is really a de-watering oil rather than a penetrating oil and products like Plus Gas seem to work much better for disassembly. Rod |
Hopper | 23/04/2022 12:34:46 |
![]() 7881 forum posts 397 photos | PS just added a bit to my earlier post on the press-in type of Super 7 studs. Please clarify if you have ML7 or S7. Swarf, he wants to take them out to replace the Tufnol gears. |
Grindstone Cowboy | 23/04/2022 12:34:59 |
1160 forum posts 73 photos | The locknuts are fairly obvious if you look at the back of the assembly (on an ML7 at least), so if there aren't any, it may be that a differerent method was used on that particular machine. Seems unlikely though. Swarf - I think Bricky needs to replace a stripped gear, there's another thread about it. Rob Edit - Hopper got there first Edited By Grindstone Cowboy on 23/04/2022 12:44:26 |
bernard towers | 23/04/2022 13:25:39 |
1221 forum posts 161 photos | If it’s a S7 mine are pressed in and would think that the pins are shouldered. Looking from the back it looks like there is a large dia bush with a smaller dia pin in the centre. I’ll have a go at pressing one out and see what it’s all about as I don’t use this bit anymore. |
bernard towers | 23/04/2022 13:36:49 |
bricky | 23/04/2022 19:11:36 |
627 forum posts 72 photos | Thanks Bernard that explains it .My lathe is a S7 Plus large bore,thanks to all who replied. Frank |
