RS Components Datasheets
The Mad Professor15/04/2022 15:52:46
12 forum posts
Many years ago (at least 20?), RS used to issue paper "datasheets" on their products. One such product was a transformer kit. This had a pre-wound 240 volt primary winding and space for a secondary of your own choice. They no longer offer this product (EU regulations?). Does anyone have a copy of the original datasheet? I have no idea of the Datasheet Number but the RS Stock No. was182-9925. Can anyone help or do they have access to the old red/brown binders of the datasheets?
Thanks.
Mike Poole15/04/2022 16:34:34
3676 forum posts
82 photos
This is an unhelpful reply but I remember the data sheet library very well, my job evolved into a hands off role and the satisfaction of bench repair work was left behind, happy days though.
Michael Gilligan15/04/2022 16:50:27
23121 forum posts
1360 photos
You are probably already aware, but RS does identify the manufacturer’s part number:
https://uk.rs-online.com/web/p/chassis-mounting-transformers/1829925
Edit: __ and, as if by magic
https://www.vintage-radio.net/forum/attachment.php?s=49150bd2447f5318c0a5401da68988ee&attachmentid=137737&d=1487237293
https://www.vintage-radio.net/forum/attachment.php?attachmentid=137738&d=1487237293
Refhttps://www.vintage-radio.net/forum/showthread.php?p=919570
Edited By Michael Gilligan on 15/04/2022 17:05:54
SillyOldDuffer15/04/2022 17:05:00
10668 forum posts
2415 photos
I've failed too! Got an RS transformer in it's box, except the box is for a 200VA 208-579 and it contains a 100VA 207-734. No datasheet and the transformer markings don't help.
Presumably you want to know how many turns are on the primary to calculate the number needed to give a secondary voltage. Another way, if you have a transformer, is to wind 40 turns as a temporary secondary and measure the voltage, V. Then volts per turn = V/40.
I'm sure a Leave expert will soon be along to explain why transformer kits still aren't available even though we've left the EU...
wink
John Baguley15/04/2022 18:21:00
517 forum posts
57 photos
Here you go:
I bought one of the kits many years ago but never used it.
David-Clark 115/04/2022 18:25:34
271 forum posts
5 photos
This brings back unhappy memories. Laminating hundreds of little transformers for the MOD. BORING.
The Mad Professor16/04/2022 09:03:57
12 forum posts
Thanks John, I knew that someone "out there" would have a copy of the sheet available! All I have to do now is get some laminations of the right size (available from ASCO - https://ascocomponents.co.uk/ ) and off I go!
Kind regards,
The Mad Professor.
Michael Gilligan16/04/2022 09:35:39
23121 forum posts
1360 photos
Posted by The Mad Professor on 16/04/2022 09:03:57:
Thanks John,
You’re welcome devil
Yes, i do realise that John’s scans are much, much, prettier than the ones found.
Simon Williams 316/04/2022 09:44:30
728 forum posts
90 photos
Dunno if it helps, but I've got three of these kits albeit with a different part number here, RS 805-114. I've no idea if I've still got the data sheet, but if they are any use to you they're yours for the cost of postage.
PM me if it's of interest to you.
Oh and I'm in North Gloucestershire nearly Monmouth btw.
Rgds Simon
