Greensands | 15/04/2022 14:06:50 |
449 forum posts 72 photos | Hi - Anyone out there with a knowledge of the old DOS commands? I have a number of DOS files on my workshop computer (W98) having a file extension .CON which I would like to be able to display in date order. Reference to the manuals indicate that the generic command DIR *.CON can be modified by a /switch attribute which I can get working when using /p (to display one screen at a time) but have not been able to get the /d attribute working in order to display the files in date order. Any suggestions as to where I am going wrong?. |
Grindstone Cowboy | 15/04/2022 14:21:43 |
1160 forum posts 73 photos | dir *.con /od Edit - if you type any DOS command with the /? switch, it lists all available options e.g. dir /? Rob Edited By Grindstone Cowboy on 15/04/2022 14:23:27 |
SillyOldDuffer | 15/04/2022 14:24:10 |
10668 forum posts 2415 photos | Posted by Greensands on 15/04/2022 14:06:50:
... I have a number of DOS files on my workshop computer (W98) having a file extension .CON which I would like to be able to display in date order. Reference to the manuals indicate that the generic command DIR *.CON can be modified by a /switch attribute which I can get working when using /p (to display one screen at a time) but have not been able to get the /d attribute working in order to display the files in date order. Any suggestions as to where I am going wrong?. Microsoft changed DIR slightly with every release! This website seems to cover all the variations.
Try DIR *.CON /O:D or, to reverse the order DIR *.CON /O:-D /T controls which datetime is used by the sort if the default isn't what's wanted. TC=create; TA=last read; TW=last write Dave |
GordonH | 15/04/2022 14:37:45 |
64 forum posts 5 photos | Greensands, Open up a DOS Shell by typing "cmd" (without the " symbols) in the search window then press enter.. The Dos pop up window will open. Typing "Help " followed by any command name, will display format of the command and the switches which can be used. One useful switch that is not listed is the > character followed by a file name. This will divert the screen output into the named file, a very useful feature Gordon Below is an example from Windows 10, I added the last line to show the piping command:- C:\Users\gordo>help dir DIR [drive:][path][filename] [/A[[:]attributes]] [/B] [/C] [/D] [/L] [/N] [drive:][path][filename] /A Displays files with specified attributes. Switches may be preset in the DIRCMD environment variable. Override C:\Users\gordo>help dir >help.txt Edited By GordonH on 15/04/2022 14:39:18 Edited By GordonH on 15/04/2022 14:41:03 |
Greensands | 15/04/2022 14:44:12 |
449 forum posts 72 photos | Yes, I now have success!. Many thanks GC and SOD |
Ady1 | 15/04/2022 17:24:15 |
![]() 6137 forum posts 893 photos | I seem to have a residual bit of fluff in my head which says FAT32 was date orientated and NTSF was alphabetic |
