BASS 666 | 25/02/2022 19:30:43 |
![]() 49 forum posts 38 photos | i found my serial number and it's KSL 71468 the L has a bit missing but i still think it's an L .. i can't find it on any of the online charts to see what year the lathe was made .. it's a tri leva, does anyone know where to find the info i need ? thanks guys .. |
JA | 25/02/2022 19:49:32 |
![]() 1605 forum posts 83 photos | Have you looked at www.lathes.co.uk? This is the first place to go to for such questions. However my browser is blocking access to it at present. JA |
Former Member | 25/02/2022 20:00:25 |
1085 forum posts | [This posting has been removed] |
BASS 666 | 25/02/2022 20:34:26 |
![]() 49 forum posts 38 photos | Posted by JA on 25/02/2022 19:49:32:
Have you looked at www.lathes.co.uk? This is the first place to go to for such questions. However my browser is blocking access to it at present. JA yes mate but i couldn't find it ... |
BASS 666 | 25/02/2022 20:35:50 |
![]() 49 forum posts 38 photos | Posted by br on 25/02/2022 20:00:25:
My chart gives it at 1963 to 1966 ? oh ok .. i just can't find it anywhere .. amazing the way these things work being so old ... |
Don Cox | 25/02/2022 20:59:30 |
63 forum posts | Myford Ltd website also has what appears to be a full record of serial numbers. To be a Tri leva it has to be an ML7 ( beware that the Tri leva bits may have been added at a later date) you might be able to read the number again with a more enlightened view to try and make it fit into the ranges published there |
BASS 666 | 25/02/2022 21:10:22 |
![]() 49 forum posts 38 photos | Posted by Don Cox on 25/02/2022 20:59:30:
Myford Ltd website also has what appears to be a full record of serial numbers. To be a Tri leva it has to be an ML7 ( beware that the Tri leva bits may have been added at a later date) you might be able to read the number again with a more enlightened view to try and make it fit into the ranges published there i can't find any site that has serial numbers beginning with KSL .... not to worry i have been told 63 to 66 so that's good enough ... |
Former Member | 25/02/2022 21:22:35 |
BASS 666 | 25/02/2022 21:34:38 |
![]() 49 forum posts 38 photos | Posted by br on 25/02/2022 21:22:35:
Double checking the letters SK i think are Super 7. As trileva fitted to ml7 the corresponding year for that serial no is 1966. I think if you say 1966 you will be about right thanks mate appreciate it ... |
