Access for maintenence
Roger Best | 30/01/2022 11:39:02 |
![]() 406 forum posts 56 photos | How do you get to the underside of your engine? I need to give mine a good clean and repair the paint, its more than just oiling the motion. Do you just tip it on something soft? I am minded to bolt disks of plywood to the buffer beams but I need to know the centre of gravity. I have a bad back and my workshop is very cramped, so no heavy lifting for me, only controlled and safe. My Polly 4 is about 40kg so one end at a time to lift. ta |
Roger Best | 30/01/2022 12:04:07 |
![]() 406 forum posts 56 photos | A few pictures of my new engine on its trolley, and the areas that need work. |
Perko7 | 30/01/2022 12:26:08 |
452 forum posts 35 photos | My engine weighs about 50kg, but I can't roll it onto it's side as the side steps are fairly delicate and would be bent in and foul the motion, so I usually tip it onto one end. It needs some stabilising supports but at least I can see and get to all the bits while standing. Previously I would lay some rails between the fixed workbench and a mobile bench of a similar height and roll the loco onto the rails. Meant I had to sit on a low stool to get to the underside and was a bit hard on the back and neck muscles as well as usually needing temporary additional lighting. |
Jon Lawes | 30/01/2022 16:51:18 |
![]() 1078 forum posts | I use a spit connected to the buffer beams. It has saved a huge amount of time and effort and allows for quicker servicing and inspection to find out what is working loose... |
Robert Butler | 30/01/2022 17:23:18 |
511 forum posts 6 photos | If it's possible, can you cut two circles of thick Plywood of sufficient diameter and fix to the buffer beams and roll it into whichever position you require. A timber brace can be screwed to the circles to enable its position to be locked. Robert Butler
Speedy Builder5 | 30/01/2022 18:07:32 |
2878 forum posts 248 photos | Follow Locomotive transport on this site for some other ideas |
alan ord 2 | 30/01/2022 18:26:58 |
![]() 145 forum posts 41 photos | +1 for Jon Lawes. I made my own fixture for working on my loco. Pictures in my album. Alan |
Roger Best | 30/01/2022 20:19:02 |
![]() 406 forum posts 56 photos | Ta guys, I have the means to follow Robert's advice, I like the spit solutions, but that is a big job in its own right and I need this done for testing day. Transport is another issue entirely. I am still interested in what people do. |
