How tight should a Mamod drive-belt be ?
Bob Unitt 1 | 28/01/2022 12:24:02 |
![]() 323 forum posts 35 photos | I've acquired some Mamod drive-belt (the screw-together kind) for the governor on my Lady Stephanie, to replace the elastic band used currently. I have no idea of what length of belt I need, so how much tension should there be on the band once it's fitted ? |
john halfpenny | 28/01/2022 14:41:26 |
314 forum posts 28 photos | Not very much, but of course depends on the torque you are trying to transmit/overcome. However it's easy to start slack and snip bit by bit off the female end before re-attaching the (tapered) male end |
Former Member | 28/01/2022 14:49:20 |
1085 forum posts | [This posting has been removed] |
Bob Unitt 1 | 28/01/2022 16:05:26 |
![]() 323 forum posts 35 photos | Thanks. The guy I bought it from said that once it was screwed together it was impossible to unscrew - is that not the case ? |
Former Member | 28/01/2022 16:11:50 |
Roger Best | 30/01/2022 21:11:18 |
![]() 406 forum posts 56 photos | 1/2" is too much to chop off. They are very sensitive to just a few mm plus minus. Just go carefully. Obviously it varies with size of garter spring, and length required. i am no longer surprised when I get it wrong. |
Bob Unitt 1 | 31/01/2022 09:46:46 |
![]() 323 forum posts 35 photos | Thanks for the info. I have at least 1/2" jockey-wheel adjustment on a length of about 5" - will it be sufficient to make it fit closely but not stretch, and use that adjustment to get the tension right ? |
Former Member | 31/01/2022 10:28:03 |
Bob Unitt 1 | 03/02/2022 22:28:20 |
![]() 323 forum posts 35 photos | Thanks guys, all done now after 3 attempts - those belts don't join easily, do they ? If anyone else is making a Lady Stephanie and intends to use the Mamod belt, the length you need is 7.375 inches.
