Russ B | 26/01/2022 13:34:43 |
635 forum posts 34 photos | I have an issue on a motor speed controller that I've been unable to solve (I seem to have created or uncovered a different issue!?) I'm afraid my knowledge on this repair comes from a google search and a bench test based on my limited knowledge of what is to me, a complex piece of electronics. |
Les Jones 1 | 26/01/2022 14:42:53 |
2292 forum posts 159 photos | The controller should have two outputs to the motor. The one that goes to the field winding will be a fixed voltage. The one that connects to the brushes will be controlled by the speed potentiometer. Which connection did you get a constant reading of 110 volts ? I have not been able to find the schematic online for your speed controller But I do have a schematic of the KBIC 240D controller. If yours is a similar design it would explain why you get a reading of 110 volts rather than about 240. The 240D uses half wave rectification for the field supply so you will be reading the average voltage of half wave rectified 240 volts. I suggest that you measure the voltage to the armature and see if that is present and varies with the speed potentiometer setting. It would be helpful if you could provide a link to the information on your controller and any information on the motor. Les. |
Adrian R2 | 26/01/2022 17:05:42 |
196 forum posts 5 photos | If you just want it to work, rather than enjoy the fun of fixing it then a couple here at unspecified clearance price: http://www.toolco.co.uk/categories/clearance-electrical-items (Not a recommedation but popped up when I searched to see what it was you were struggling with) |
John Haine | 26/01/2022 17:23:15 |
5563 forum posts 322 photos | Posted by Russ B on 26/01/2022 13:34:43:
... How many wires go to the motor? You mention a field terminal there, but also later on that the motor runs connected to a 9V supply. If the motor has a wound field there should be 2 wires to the field and 2 for the commutator, though it's conceivable that they common one end of each winding to get only 3 wires. If it is wound field it probably wouldn't be keen on running from only 9V. |
Les Jones 1 | 26/01/2022 17:58:23 |
2292 forum posts 159 photos | Hi John, Les. |
Russ B | 27/01/2022 11:31:04 |
635 forum posts 34 photos | Hi,
Russ B | 27/01/2022 11:36:41 |
635 forum posts 34 photos | Posted by Les Jones 1 on 26/01/2022 14:42:53:
The controller should have two outputs to the motor. The one that goes to the field winding will be a fixed voltage. The one that connects to the brushes will be controlled by the speed potentiometer. Which connection did you get a constant reading of 110 volts ? I have not been able to find the schematic online for your speed controller But I do have a schematic of the KBIC 240D controller. If yours is a similar design it would explain why you get a reading of 110 volts rather than about 240. The 240D uses half wave rectification for the field supply so you will be reading the average voltage of half wave rectified 240 volts. I suggest that you measure the voltage to the armature and see if that is present and varies with the speed potentiometer setting. It would be helpful if you could provide a link to the information on your controller and any information on the motor. Les. This link is also referencing a KBIC, and later refers to two models, a BC2000 and a BC2200, and everything in it, seems to match almost exactly to the board in hand. |
John Doe 2 | 27/01/2022 12:55:19 |
![]() 441 forum posts 29 photos | A very general comment: Depending on the design, power switching circuits can fail catastrophically if one element fails, and a fault can easily kill many other components around the failed one, faster than any fuse can operate. At work many moons ago, I took over a colleague's repair of a switching power supply in a television monitor. I had to replace about four beefy output transistors that had failed. My colleague walked in and said "I just changed all those". "Yes, says I, and yours all blew again", (because the original fault had still been present.) Hopefully not the case here, but just to warn you. |
Les Jones 1 | 27/01/2022 13:00:32 |
2292 forum posts 159 photos | You have not answered the question of which connections measured 110 volts (Field connections or armature connections.) Les. |
John Rudd | 27/01/2022 13:08:41 |
1479 forum posts 1 photos | The Chinese lookalike boards similar to the KBIC control boards are essentially copies using thru hole components, although some later derivatives use smd devices too. The mains AC is used to drive a full wave bridge rectifier comprising 2 S*025L thyristors and similarly rated diodes.A third diode is connected directly across the output. The F+ and F- supply is generated using two low current diodes( typically around 1 amp). The full wave bridge uses phase angle control with a zero crossing detector to generate the speed control. A startup ramp is generated using a resistor and capacitor network that is adjustable to give a soft start, current overload sensing and motor load compensation is also featured on these boards. The Seig speed controllers are similar but principally operate the same way.( are some subtle differences in how the 12v rail is provided). Repairing these boards is not for the faint hearted. Fake parts abound, beware where you buy replacements from Edited By John Rudd on 27/01/2022 13:09:11 |
Russ B | 28/01/2022 10:09:17 |
635 forum posts 34 photos | Posted by Les Jones 1 on 27/01/2022 13:00:32:
You have not answered the question of which connections measured 110 volts (Field connections or armature connections.) Les. Sorry Les, I don't think there is a field, its a brushed permenant magnet motor, all in good condition and running smoothly to my untrained eye. |
Russ B | 28/01/2022 10:28:14 |
635 forum posts 34 photos | Posted by John Rudd on 27/01/2022 13:08:41:
The Chinese lookalike boards similar to the KBIC control boards are essentially copies using thru hole components, although some later derivatives use smd devices too. The mains AC is used to drive a full wave bridge rectifier comprising 2 S*025L thyristors and similarly rated diodes.A third diode is connected directly across the output. The F+ and F- supply is generated using two low current diodes( typically around 1 amp). The full wave bridge uses phase angle control with a zero crossing detector to generate the speed control. A startup ramp is generated using a resistor and capacitor network that is adjustable to give a soft start, current overload sensing and motor load compensation is also featured on these boards. The Seig speed controllers are similar but principally operate the same way.( are some subtle differences in how the 12v rail is provided). Repairing these boards is not for the faint hearted. Fake parts abound, beware where you buy replacements from Edited By John Rudd on 27/01/2022 13:09:11 John, As for mica washers..... the board and wiring had been fettled and given that the armature was accidentally connected to the field terminal adjacent I would guess finer details like mica washers slipped the attention of whoever dissasembled it in the first place. That said, when I tested it, it was on a non conductive bench, out of the machine, the heat sink was attached, however where as the SCR's and Diodes connected dry, directly to the annodised aluminium, I slipped a 0.3mm thermal pad under them believing it would be useful? I feel like I shouldn't be touching this at all but as it didn't work, I felt I had nothing to lose and when I identified a clearly faulty SCR I thought I'd cracked it! I hope I haven't done more harm that good! |
Les Jones 1 | 28/01/2022 12:28:04 |
2292 forum posts 159 photos | I realised after re reading you first post that I assumed it was a shunt wound motor with you mentioning field connections. It is useful to know it is definitely a permanent magnet motor. What is the information on the plate on the motor. (Voltage, current wattage , horsepower.) Les. |
Russ B | 31/01/2022 13:40:14 |
635 forum posts 34 photos | Les, this information only partially covers your request, more information to come tonight. No information on the motor plate, perhaps its once had a sticker on it, but I doubt it! The speed controller board lists: Input 115/230VAC, 50/60hz, 1PH, 9A The Original Diodes (still in place) read D8020L 9E5HB As for wiring, could I refer you to page 13 on the manual linked above, with the exception that my P1 and P3 terminals are reversed vs this image (if I am to trust the printing on the circuit board). And also my machine is configured with a single fuse in the incoming live, and another in the motor A+ side, neither of which have been problamatic so far (both F5A if I recall correctly but don't hold me to that). My 3pin wall plug had a 3A fuse which is perhaps a little low if the lathes 3.5A rating plate is to be trused but I thought it would be ok for testing without load. I did try a 5A, it blew that too. |
John Rudd | 31/01/2022 14:50:55 |
1479 forum posts 1 photos | Russ,
The following notes might aid your fault finding... The component designations are for a KB controller, they may be different to that of the Best item...
(A) Check resistance across L1 and L2. Reading should show infinite or open circuit. Be sure to reverse leads across L1 and L2. Reading should still be infinite. Measurement values shown below are approximate only . |
Russ B | 31/01/2022 19:54:57 |
635 forum posts 34 photos | Les, John, I'm afraid time, tiredness and the other half watching TV has got the better of me tonight so this will have to wait, I'll get grumbled out if I trip the RCD which can happen from time to time when I'm messing with stuff I shouldn't be although I don't recall this ever cause it to happen!
John, this testing seems interesting, I presume D4, D7 and D2 are my 3 diodes, I'll have a look and see if they're referenced similarly. Do you have any diagrams or could point me to an image online/describe which is which. |
Les Jones 1 | 31/01/2022 19:55:38 |
2292 forum posts 159 photos | As the SCRs and diodes have the L suffix they do not need to be insulated from the heatsink.. So that is one of the possible problems eliminated. Don't worry about P1 and P3 being reversed. That would just swap over the low and high speed ends of the potentiometer. I would expect a reading of about 10 volts between these two points. The voltage on P2 With respect to P1 or P3 should change as the potentiometer is rotated, Les. |
