James Alford | 20/01/2022 07:59:35 |
501 forum posts 88 photos | A slightly unusual question, perhaps, but has anyone any experience using casting or moulding rubber? I wish to try making some rubber mats for an old car; the type that mould over and around the transmission tunnel. I have been looking for a suitable product to use and am considering Devcon Flexane 80. However, it would be good to hear from anyone who used this, or a suitable alternative product, before spending £80.00. Regards, James. |
Ramon Wilson | 20/01/2022 08:56:24 |
![]() 1655 forum posts 617 photos | I haven't used it in such a manner so this is just a suggestion but there are many silicone moulding rubbers available in varying degrees of flexibility that would probably give you what you want. Pigments are also available to colour it - to the degree you want - without affecting its properties. An eBay search would probably help but the name Alec Taranti as a supplier springs to mind. It's been a long time since using it for mould making but it will certainly flow and set to minimal thickness for what you describe Hope that's of help Tug |
Speedy Builder5 | 20/01/2022 09:03:55 |
2878 forum posts 248 photos | I have made a mold of a 14" high garden cherubim. I used 3 coats of silicone molding rubber and then a a backing cold of re-inforced plaster of Paris (in sections). The silicone is not rigid enough to support the Devcon or other product on its own as the silicone mold is probably only 3/16" thick or so. Bob |
James Alford | 20/01/2022 09:45:30 |
501 forum posts 88 photos | Thank you for the suggestions. The idea of using plaster of Paris to support the mould is a good one one of which I had not thought. I had not considered using silicone for the actual mats as the only silicone I have encountered it is too fragile to stand up to that type of use. However, I shall look at the suggested supplier to see whether there is a more robust style that would be appropriate.
Thank you.
James
Russell Eberhardt | 20/01/2022 10:09:39 |
![]() 2785 forum posts 87 photos | I would stick to polyurethane rather than silicone. Polyurethane looks and feels more like real rubber and is stronger. The disadvantage is that it will stick to anything and needs a good release agent on the mould. Russell |
