Y C Lui | 09/01/2022 05:16:16 |
84 forum posts 35 photos | I have problem in getting good finish when side milling with my Emco FB2 mill. I recently did a cutting test under different settings and found that the relatively poor finish occurs only if the cutting is done along the Y axis. The gibs of the table have already been readjusted so loose gibs should not be the cause. The only reason I can think of is the poorer rigidity of the head which is expected to flex / oscillate more along the X axis. Would like to hear you guy's opinions Typical finish of side milling along the Y axis : https://www.hobby-machinist.com/attachments/p1060758-jpg.391089/ Test cut set up ( milling along the X axis ): https://www.hobby-machinist.com/attachments/img_6365-jpg.391335/ Test cut results : https://www.hobby-machinist.com/attachments/3_28-jpg.391342/
Edited By Y C Lui on 09/01/2022 05:18:19 |
Joseph Noci 1 | 09/01/2022 06:36:42 |
1323 forum posts 1431 photos | Says I need a Login to see your Photo's YC... Perhaps you can put them in an album on this forum? I have three FB2's....although one has a J&S head. The other two are original, except for one being CNC'd. I obtain very good finishes in Ali with with greater DOC than what you have attempted, so you should be able to do it easily. What does it sound like when cutting? Just the normal load gearbox/ ( esp at 2000 rpm..) Have you tried lower rpm? What happens when you vary the feed speed? How is the cutter held - ER collet, Morse taper shank cutter? I have an 'abused', now replaced, FP2 quill where the morse taper for about 25 to 30mm from the mouth was badly damaged, as though the previous dolt-owner had not pulled up the taper and so it slipped, or had crud embedded, etc. ( its a long story..) This resulted in a morse taper inserted showing some side wobble under load - how does your quill taper look? The obvious things are taken care of? - cutter edge quality, workpiece stability, etc? would like to see the photos..esp the vise type,height, X and Y construction, etc. Joe |
Y C Lui | 09/01/2022 07:31:45 |
84 forum posts 35 photos | Hi Joe, Thanks for the reply. I have created an album and the photos can be viewed here : Typical finish of side milling along the Y axis : Test cut set up ( milling along the X axis ): https://www.model-engineer.co.uk/sites/7/images/member_albums/111244/902861.jpg Difference in finish. X axis vs Y axis : https://www.model-engineer.co.uk/sites/7/images/member_albums/111244/902862.jpg The sound is the same when cutting along the X axis ( good finsh ) and Y axis ( bad finish ). There is not any chattering sound although the finsh may indicate some chattering is happening when cutting along the Y axis. Yes, I have tried increasing the feed speed from about 80 mm/min to 200 ( manually done so it's just a rough indication ) and the result is just the same. Comparison : https://www.model-engineer.co.uk/sites/7/images/member_albums/111244/902866.jpg The quill taper is in very good condition I would say. I have got a Big-Kaiser boring head with a tang-end taper and it never dropped out by itself. I bought the mill new some 25 years ago and never used it much until now. This is just a hobby-grade machine so I do not expect a lot from it. What puzzles me is why the finish of side milling is so different for the X and Y axes. I have asked about this in the hobby machinist forum. The guys there have no clues and referred me to this forum for assistance.
Edited By Y C Lui on 09/01/2022 07:32:27 Edited By Y C Lui on 09/01/2022 07:33:25 Edited By Y C Lui on 09/01/2022 07:36:29 Edited By Y C Lui on 09/01/2022 07:42:58 |
JasonB | 09/01/2022 07:52:44 |
![]() 25215 forum posts 3105 photos 1 articles | If you are getting a difference between X and Y then it is unlikely to be spindle or cutter related as they are constant. More likely gib adjustment of backlash particularly if you were climb milling on the finish cut. |
Martin Connelly | 09/01/2022 09:24:23 |
![]() 2549 forum posts 235 photos | For me it is rare to get as good a finish when side cutting as face cutting on top of a workpiece. Here are some things that may help. You are using a 2 flute cutter. Another thread regarding slot cutting has the mention by Jason that he always uses 3 flute cutters. These are a better option than 2 flute because they are stiffer. A 2 flute cutter can be looked at like a twisted ribbon, even carbide 2 flute cutters are not as stiff as 3 flute cutters. I think there may be too much play in the gibs and when you are unlocking an axis it becomes too loose, try pinching the moving axis slightly so there is some drag and see if that improves things. I would not rely on just two clamps holding that vice to the bed like that, I would use four because a heavy cut may grab the workpiece and twist the vice if there are no tenons locking it into the slots. Try a larger diameter 3 flute HSS cutter with a polished finish, coated cutters are no good for aluminium alloys, the coating just encourage the aluminium to stick to the cutting edge and give a poor result. See if you get a change in the finish from a faster or a slower speed or feed, sometimes the cut just hits a resonant frequency of the machine and a different number of cutting edges or a small change in speed (with a corresponding change in feed rate) may change the frequency and completely change the resonance of the machine, these mills are only small even at 300kg compared to an industrial machine. This makes them more prone to resonance and vibration. Make sure it is always cutting and not rubbing, this will show up as a constant flow of evenly sized chips coming off the cutter. Martin C Ps Get a ball bearing nut for the ER collet chuck if possible. They allow a far greater clamping force on the tool with the same applied torque, there is a possibility that the collet is not closed down tightly enough. Edited By Martin Connelly on 09/01/2022 09:27:49 |
Kiwi Bloke | 09/01/2022 09:43:44 |
912 forum posts 3 photos | If there is any movement of the head around the column (or the column in its housing), the depth of cut can vary a little bit as you cut across the table (your y-axis), because of the x-axis component of any slight head rotation about the column, which will manifest itself as depth of cut instability. The same movement will have little effect on cuts along the table (your x-axis), because any movement will cause a tangential vibration, with with minimal y-axis component, thus minimal depth of cut variation. Think about the geometry if this isn't clear. Sorry, I don't think I've explained this very clearly - it's getting late... The vertical guidance of these machines isn't exactly the best design for rigidity, and its adjustment is a bit tricky. Read the manual, otherwise you can get confused, with adjustment screws fighting each other. Therefore, unless feeding vertically, lock the vertical head movement (z-axis). Are you sure you have locked the head to the column (vertical feed lock), and that the column is tight in its housing? Put a DTI on the quill, sensing along the table (x-axis), and apply brute force to the head, trying to rotate it about the column. It should be possible to correct this problem by adjustment, or attention to the locks. As others have said, the machines are very capable of excellent results. Edited By Kiwi Bloke on 09/01/2022 09:46:47 (Too close to bed-time for clarity of thought or expression) Edited By Kiwi Bloke on 09/01/2022 09:53:31 (Oh, good grief! I'm fading. Hope nurse will tuck me up in bed soon...) Edited By Kiwi Bloke on 09/01/2022 09:56:32 |
Andrew Johnston | 09/01/2022 10:20:44 |
![]() 7061 forum posts 719 photos | Feedrates are way too slow, leading to rubbing rather than cutting. With the parameters given I'd be feeding five to ten times the rates stated. Plus one for an aluminium specific cutter. Aluminium is one of those materials when climb milling on the final cut can be advantageous in getting a good surface finish. Andrew |
Joseph Noci 1 | 09/01/2022 10:38:22 |
1323 forum posts 1431 photos | YC indicates that a good finish is obtained in X so I would think that to a large degree eliminates feedrate issues, cutter type, etc. Kiwi Bloke's comments should be investigated methodically. Make sure the four bolts clamping the column mount to the XY table base are tight - likewise the two clamp bolts that close the split in the column mount. I run my FB2 with the gibs perhaps a little tighter than most - grab the Y table at its ends and push one end, pull the other - there should be no deflection. As KiwiBloke said, the geometry is an indicator here - make sure the slide on the column is really tight - perhaps for testing, release the grub limiting screws on the column slide ( they assist in setting the 'gib' effect when removing play on the slide to column interface) and tighten the two bolts that close the slide split so that the head cannot move. See if the finish improves? Likewise lock off the quill so it cannot move. |
Graham Meek | 09/01/2022 11:25:59 |
714 forum posts 414 photos | I used to suffer with this problem many years ago when I first had the first of my FB 2's. The finish using the side of the endmill in the X-Axis was always perfect. However when using the same cutter on the Y-Axis it was a different story. Holding the machined face at different angles to catch the light would show striations along the face. Aluminium was particularly bad at this, but steel being better. First thoughts were the Gib being loose on the Y-Axis, but this adjustment met with my satisfaction. I finally traced the problem to the actual cutters being used. These were made by Osborn, so a good make. However the cutting angle on the side of the Osborn cutter was 5 degrees. Changing this to 7 degrees totally removed the problem. The cutters also cut with less effort. The downside is the cutter life is less when compared to the 5 degree. As I sharpen my own cutters this is not a problem for me. I have found the Helix angle of the cutter also influences this problem. Some straight flute cutters I have do not show any signs of this problem. Regards Gray, |
Andrew Johnston | 09/01/2022 11:33:18 |
![]() 7061 forum posts 719 photos | For me at least the links in the OP lead to a page where I would have to log in to view. So I haven't been able to see the finishes for myself. But I apologise for wasting everyones time by making silly suggestions. It won't happen again. Andrew |
Y C Lui | 09/01/2022 12:20:39 |
84 forum posts 35 photos | Thanks for all the replies. Really appreciate it. Gray's reply suggests that this can be a common problem of FB2s. Glad that the problem can be solved / alleviated by changing cutters. I will explore further in that direction. May be trying out 3 fluters designed for cutting alumnium ( no coating , rake angle may be larger as well ) I have subsequently done further checking as suggested by Joe and Kiwi Bloke. The set up is shown in this photo With all the axes locked except for the Y axis. I pushed the table at the right and left sides with all the muscles I have got and the indicator reading only changed by about 0.003 mm. However, when I pushed the mill head with relatively little force. the change in dial reading was 0.015mm, a lot larger. Checked all the six screws mouting the column to the base, all are super tight. Then I followed Joe's suggestion to loosen the two set screws on the column slide. Doing so is to take out any excessive play between the slide and the column. This was confirmed by the fact that I could not move the slide even if the Z-axis locking level was loosen. With this done and the Z axis locked up again, the sideway movement of the head upon being pushed was just reduced very slightly to about 0.012 mm. Then I did a test cut and the finish was just the same, ie, still bad. Can it be concluded that the bad finish when cutting along the Y axis is due to the poor rigidity of the head along the X axis ? Edited By Y C Lui on 09/01/2022 12:49:15 |
Martin Connelly | 09/01/2022 13:14:42 |
![]() 2549 forum posts 235 photos | Andrew, on posts by the OP under his name there is a link stating a number of photos. This will take you to the relevant photos in the forum album. Martin C |
Martin Connelly | 09/01/2022 13:25:23 |
![]() 2549 forum posts 235 photos | I think when you are cutting along the Y axis the force vectors on the cutter are acting approximately towards or away from the column centre so rotational forces on the head are unlikely to cause any rotational deflection as they are small. When you are doing the cut along the X axis the force vectors are well away from the column centre line so there is more likelyhood of the head and the column twisting under the forces. Even though the movement is small it could be enough to cause issues as it is significant compared to the cutting depth. Personally I have never cut an edge along the X axis because I have never needed to so I don't know if what you have got is typical of these machines. Martin C |
DiogenesII | 09/01/2022 14:05:44 |
859 forum posts 268 photos | Nothing to add, other than that in your final photo with the vice arranged to cut in Y, the clamps look as if they are too far back, there will be a tendency for the work to 'bounce', because the vice is free to lift at the 'operator-end'. The clamps ideally need to be central to the part being machined, or better still, supplemented with another pair closer to the front of the table. I've taken the liberty of posting the photo, for which I hope you will forgive me, I felt it would help others to provide a more useful response if they could easily see the set-up... |
Kiwi Bloke | 10/01/2022 08:45:26 |
912 forum posts 3 photos | Y C Lui's deflection measurements would probably be impressive for a small jig borer. I wondered how my FB-2 would compare. My FB-2 is accessible, but not set up for use. However, the locks work well, and everything relevant that should be tight is tight. My spring balances have gone into hiding, so only a very rough test was possible. The head was eyeballed to be about the same height from the table as in the pic. Applying something like 20 kg force to the head casting, along the table (x-axis) in each direction produced a TIR in line with the quill of approx 0.03 mm with the vertical lock tight, and 0.1 mm with the lock free, confirming my reservations about this aspect of the design. This is an order of magnitude worse than Lui's measurement! Now I'm worried! For completeness, corresponding y-axis deflection test produced about 0.05 mm TIR and wasn't affected by the vert. lock. I'm not surprised by the results I got: if you lean on machine tools with enough determination, you discover they are made of rubber. It would be interesting if one of the other FB-2 users, who get reliable results from their machine, could possibly do a similar quick test, and post results. Any takers? Joe? Gray? |
Kiwi Bloke | 10/01/2022 09:07:10 |
912 forum posts 3 photos | Posted by Kiwi Bloke on 10/01/2022 08:45:26: Blah, blah, blah... This is an order of magnitude worse than Lui's measurement! Now I'm worried! Actually, I should be more worried about my inability to think... I meant twice as bad, not an order of magnitude. Realised too late to edit. |
Graham Meek | 10/01/2022 12:08:58 |
714 forum posts 414 photos | Rotational deflection of the Column is resisted by the Guide Bar set into the Column. In order to allow the Head to slide up and down there needs to be a small clearance. If this clearance were 0.001mm then the deflection at the clock just taking up the clearance would be 0.01mm as the lever ration is a factor of 10. I doubt the slide would move with such a small clearance, it would be more likely to be 0.01mm to start with, which would give a deflection of 0.1mm at the clock. (Oil films do need a space to work in) As regards adjustment of these surfaces there is only one way to do this, and it is not, with the feedscrew attached. The head needs to be removed from the Column. It will rest happily on the table with a couple of parallels and no heavy lifting is involved. As the separation movements can be controlled by the table feedscrews. The Column is removed from the Casting Socket and the above mentioned Gib slackened. My bench vice with suitable protection pieces will just grip the Column. Adjustment can then be made to the Slider to Column interface. It should glide effortlessly from one end to the other with a faint hint of resistance, or drag, but no play. I find this adjustment gives a better result with dry contact surfaces. Oil is only applied once the slider to column is adjusted. The Gib is then adjusted such that it removes any rotational movement but does not interfere with the initial adjustment. Do this the other way around and expect trouble. Having the above adjustments too tight will just prematurely wear the feed-nut, (expensive), and the handwheel bearings. Back to the original plot, The Vice set-up shown in the picture is not what I would do. It is probably done to maximise the amount of slideway contact, but the clamping arrangement is nowhere near where the cutting is taking place. It induces another Lever moment. The main force resisting cutting, when cutting with the side of the endmill in the Y-Axis, will be along the Y-Axis. The reaction to this force will tend to deflect the head upwards, if it can. A small Resultant reaction force will be trying to deflect the milling head to the right in the set-up shown, but will also be trying to lift the job, the vice, the table and the Y-Axis slideway. (Helix angle on the cutter). This is why manufacturers of our range of machine tools always tell us to lock those slideways not in use. Regards Gray,
Edited By Graham Meek on 10/01/2022 12:12:28 |
