Martin King 2 | 08/01/2022 16:17:42 |
![]() 1129 forum posts 1 photos | Hi All, Here is a small engine that was in with yesterdays auction lots; any info much appreciated. 115mm tall not inc the brass bit at the top and cylinder head is 36.5mm diameter widest. Crankcase is aluminium. No idea what the brass bit is for? Cheers, Martin |
Ramon Wilson | 08/01/2022 16:36:55 |
![]() 1655 forum posts 617 photos | Looks like (not is) a Sparey 5cc - I'd say the brass serves no purpose unless its a jury rigged compression screw? Tug |
jon hill 3 | 08/01/2022 16:43:25 |
166 forum posts 40 photos | My best guess is an unfinished compression adjustor, if this is a diesel engine. I used to have a few model diesel engines and you had to lower the compression to get them started or at least hot and then gradiually increase the compression. Do you have any other pics? |
Martin King 2 | 08/01/2022 16:46:55 |
![]() 1129 forum posts 1 photos | Hi, Will post some more pics tomorrow, we are busy ploughing through our haul of stuff! Great Fun! Cheers, Martin |
KEITH BEAUMONT | 10/01/2022 12:27:18 |
213 forum posts 54 photos | Hi Martin, The diameter of the cooling muff is exactley Sparey 5cc Diesel. The crankcase is someones version of machining from solid , in place of a casting. I am curious about the brass part where a compression screw should be. Have you investigated further? Keith. |
Former Member | 10/01/2022 12:35:53 |
1085 forum posts | [This posting has been removed] |
Martin King 2 | 11/01/2022 09:34:27 |
![]() 1129 forum posts 1 photos | Hi All, The larger diameter part of the brass section seems to be in two pieces, will have a go with some soft jaw pliers when I get out to the shop late on. Here are some more pics as requested: Cheers, Martin |
KEITH BEAUMONT | 11/01/2022 12:16:57 |
213 forum posts 54 photos | Definately a version of the Sparey 5cc Diesel. The cooling muff needs turning 90 degrees. Keith. |
JasonB | 11/01/2022 12:21:16 |
![]() 25215 forum posts 3105 photos 1 articles | Although the shape of the crankcase suggests it may have been bolted down to something flat like a tether car chassis in which case the slots in the head go the right way |
KEITH BEAUMONT | 11/01/2022 19:59:06 |
213 forum posts 54 photos | I think you are spot on with that suggestion Jason. The chunky crankcase will add to the weight on the driven wheel. Keith. |
