phosphor bronze  or aluminium bronze
Kevin Bennett08/01/2022 13:07:13
193 forum posts
56 photos
Hi Guys i am at the stage of making the parts for brazing on a steam boiler
do i need phosphor bronze or aluminium bronze
Thanks Kevin
noel shelley08/01/2022 13:34:10
2308 forum posts
33 photos
Gun metal ! or a normal Cu/Sn alloy ! Phosphor bronze is for bearings, and aluminium bronze is a high strenght alloy. Noel.
duncan webster08/01/2022 14:30:06
5307 forum posts
83 photos
Ally bronze is VDiff to drill and tap, and not at all easy to silver solder. SAE660 or Colphos would be my preference
Nigel Bennett08/01/2022 14:43:49
500 forum posts
31 photos
On no account use aluminium bronze on a boiler. Although technically speaking it can be brazed using special fluxes, you can't guarantee perfect sealing with it.
norm norton08/01/2022 15:00:27
202 forum posts
10 photos
You should be using PB102 bronze for boiler bushes (PB1 is acceptable) that are silver soldered to a copper boiler shell. The other bronzes mentioned contain lead (gunmetal LG2 5%, colophos 90 4%, SAE660 7%) and zinc, and there are reports that this can affect the silver solder joint. I think the Australian code says something about it but I am speaking from memory.
For a boiler to be tested the materials used should be certified.
However, I am sure that the use of gunmetal has been common, especially for turrets, and I would guess that people have been using colophos and SAE660 with no apparent failure. Some suppliers sell 'phosphor bronze' without being aware of the differences.
Edited By norm norton on 08/01/2022 15:00:51
noel shelley08/01/2022 17:18:24
2308 forum posts
33 photos
I'm glad you said should be certified rather than shall be Norm ! For boilers built to standard or recognised plans for small ish boilers there's no requirement in the UK under club rules Etc. I've not heard of anyone here talking about the arsenic content of copper supplied to the ME trade for boilers Etc. Noel
duncan webster08/01/2022 17:21:32
5307 forum posts
83 photos
DataSheet for SAE660, note 'brazing good' 660
info from Noggin End 'contrary to popular belief Colphos can be silver soldered' colphos
Extract from AMBSC acceptable materials bushes, Alloy 836, which is near as dammit the same as colphos in chemical composition.
Kevin Bennett09/01/2022 19:59:08
193 forum posts
56 photos
Thanks for the info i will have a good look for the best action
thanks Kevin
