0 and 1BA Stainless Steel hexagons
Andrew Phillips 410/12/2021 17:45:49
30 forum posts
Hi All, I wish to make a couple of 0BA special bolts, about 2ins long, in stainless steel. The only supplier of 0.423 A/F stainless bar stock I can find on the web only sells 1m minimum length @ £20.73, and charges £18.50 minimum postage. This would mean each bolt costs 20 quid! Does anyone out there know of someone who can supply short lengths of 0 and 1BA stainless hex at reasonable prices? I have tried e-bay, M Metals and MK Metals to no avail.
I could make up bolts using 6mm rounds and nuts (I have some 0BA stainless nuts from BA Bolts) cutting a short thread at one end and using epoxy adhesive to secure the 'head', and possibly hammering the protruding end over then facing off on my lathe, but I would prefer to do the job properly.
Speedy Builder510/12/2021 17:53:59
2878 forum posts
248 photos
As you say in the last paragraph and silver solder the nuts in place.
Andrew Phillips 410/12/2021 17:59:37
30 forum posts
Hi Speedy Builder5, a good suggestion but alas I do not have the equipment or knowledge to silver solder. I read an article about soft soldering stainless, is that any good?
JasonB10/12/2021 18:08:46
Turn from round stock and machine hex head, not too much work as you say you only have a couple to make
Harry Wilkes10/12/2021 18:37:37
1613 forum posts
72 photos
Worth check out Keatley Metals link
H
duncan webster10/12/2021 22:30:00
5307 forum posts
83 photos
Use 10mm af, I won't tell anyone if you don't
Andrew Phillips 411/12/2021 10:32:11
30 forum posts
Duncan, I have a obsessively pedantic approach to mixing imperial and metric - I know it would be easier but it would always niggle me!
John Haine11/12/2021 10:47:07
5563 forum posts
322 photos
Don't think of it as 10mm but 0.394". There you go, it's imperial.
SillyOldDuffer11/12/2021 11:10:59
10668 forum posts
2415 photos
Posted by Andrew Phillips 4 on 11/12/2021 10:32:11:
Duncan, I have a obsessively pedantic approach to mixing imperial and metric ...
Not so Andrew! An obsessive pedant would cheerfully pay £20 per bolt! Trying to cut costs is a dead giveaway: it proves you're a practical man at heart. Don't deny it, embrace the dark side.
devil
Edited By SillyOldDuffer on 11/12/2021 11:11:19
Nick Wheeler11/12/2021 11:11:20
1227 forum posts
101 photos
Posted by John Haine on 11/12/2021 10:47:07:
6thou for a spanner isn't going to matter - 0.400" which gives a suitably random 2/5wink 2
File Handle11/12/2021 13:37:12
250 forum posts
Used a lot of metric 3.2 mm pop rivets recently, but drilled the holes for them with 1/8" drill. I regularly mix / interchange between metric / imperial measurement.
Speedy Builder511/12/2021 14:21:24
2878 forum posts
248 photos
Silver solder that size you can do on the gas stove, small kits on auction site will give you plenty for about £9, probably cheaper than buying hex bar. Make sure you get a kit for stainless steel, which can also be used on steel, brass, copper
Mike Poole11/12/2021 15:28:39
3676 forum posts
82 photos
I would go with Jason’s suggestion of machining the hexagon on a round bar, I have made quite a few custom fasteners for motorcycles and even used the degree markings on a swivel base vice to mill the hexagons, even a careful filing job can work ok and for a couple of bolts not to much of a drudge task. As I now have a hexagonal ER collet block this makes the job very easy on the mill. A filing rest for the lathe can produce the flats very quickly and accurately especially if you can index the chuck. Depending on what equipment you have or can borrow and a bit of lateral thinking will get the job done.
duncan webster11/12/2021 19:34:33
5307 forum posts
83 photos
But BA is a fundamentally metric thread. 0ba is 6mm OD, 1mm pitch and the rest are a geometric progression.
duncan webster11/12/2021 20:43:22
5307 forum posts
83 photos
Posted by duncan webster on 11/12/2021 19:34:33:
And according to 2 sources on the interweb, the head size is 10.5 mm, which is 0.413"
Andrew Phillips 412/12/2021 14:08:22
30 forum posts
Dunca, you are absolutely right that the correct hex size for 0BA is 0.413 ins - finger problem on mobile phone keypad! I have decided to mill the heads and have just turned a piece of 1/2 in stainless to 0.477 in preparation to setting up the milling slide on my Super 7 this evening. Thanks all for your suggestions.
Andrew Phillips 412/12/2021 14:16:10
30 forum posts
Of course, my finger trouble shows why I try to avoid mixing metric and imperial - my fingers were made in 1952 and are thus firmly imperial, so when I use them on a modern metric keyboard errors creep in!
duncan webster12/12/2021 15:37:05
5307 forum posts
83 photos
Well mine are older, but they have no difficulty with metric, believe me it's a lot easier than irrational imperial
