Michael Smith 15 | 02/12/2021 22:09:21 |
28 forum posts | I have recently acquired a large pendulum from a turret clock . It is of wooden construction with a bob of cast iron that weighs about 20 lbs and is 64 inches long. It is very nicely made and I would date it some time between 1880 ad 1920 unfortunately the clock is long gone. I would like to build a clock to incorporate it into with a gravity escapement . I don't really want to start from scratch , does anyone know of any drawings that might exist for a clock of this size as all my searches draw a blank . I would use plasma cut gears and fabricated frame . Size is not a problem as I have access to cnc plasma cutting up to 20mm on a 2 meter square table and can handle up to 4 foot diameter on my lathe I have built several of J Wildings clocks including his turret clock with a grasshopper escapement. Any ideas on escapement design and gear sizes and ratios would be much apperciated |
Michael Gilligan | 02/12/2021 22:24:05 |
![]() 23121 forum posts 1360 photos | Michael … I suggest you grab this : **LINK** https://archive.org/details/towerclockhowtom00ferso/mode/2up [ PDF download available ] I dates back to 1903, and is superb ! MichaelG. |
Michael Smith 15 | 03/12/2021 08:32:16 |
28 forum posts | Thanks for the reply , I have ordered a copy of the book. I find it difficult to read these documents on line and much prefer to hard copy in front of me I found a reprint available for about £10.00 delivered Thanks Mike |
ChrisLH | 03/12/2021 11:41:16 |
111 forum posts 7 photos | There is a very nice miniature version of the Big Ben gravity movement in the church tower in Askrigg, N Yorks. Made by Potts of Leeds. I have no other info. unfortunately. |
Michael Gilligan | 03/12/2021 11:52:10 |
![]() 23121 forum posts 1360 photos | Thanks for the reference, Chris Must stop-off there next time we are heading NorthEast https://www.britainexpress.com/counties/yorkshire/churches/askrigg-st-oswald.htm … includes no technical details, but does have an interesting photo of the old dial face. MichaelG. . Edit: … which makes me wonder a little about the pictures here: https://www.richmondshiretoday.co.uk/askrigg-time-not-chime-yet/ Edited By Michael Gilligan on 03/12/2021 11:55:56 |
Peter Cook 6 | 03/12/2021 14:48:06 |
462 forum posts 113 photos | Michael, as part of a plan to make a model of the church clock which I wind twice each week, I have been documenting the clock. You can see my original posting with a couple of pictures at A Tower Clock project | Model Engineer (model-engineer.co.uk) Although this is a Pinwheel escapement rather than gravity arm if it is of use, the details of the clock gearing are Time train Teeth Rotation I have a spreadsheet that computes the pendulum length from the gear counts in the time chain. Fiddling with it suggest that if you used these numbers and reduced the number of pins in the escape wheel to 32, then Escape Wheel Pins 32 2.50 period secs which is about 61" effective length - so possibly OK for your pendulum. In a posting on the other thread Michael pointed me to https://richard.burtons.org/2014/11/28/restoring-a-j-smith-and-sons-derby-turret-clock/ which is a restoration of a very similar Smiths of Derby clock, but that one does have a gravity escapement. Hope this is of use. Edited By Peter Cook 6 on 03/12/2021 14:50:43 |
Michael Smith 15 | 03/12/2021 15:18:59 |
28 forum posts | Peter thank you for that information ,it will give me much food for thought it is exactly the information I was looking for. I shall start to think about wheel sizes etc . Several years ago I built a green oak tower in my garden which is 25 feet tall and 12 feet square to house a copy of the clepsydra that is at Killruddery **LINK** So I will use my pendulum as part of a clock to keep it company Thanks Mike |
Peter Cook 6 | 03/12/2021 15:51:49 |
462 forum posts 113 photos | Look forward to following the build. For information most of the wheels on The clock frame is 1600m wide and 575mm front to back. All dimensions are approximate - it's fairly hard to do accurate measurements on a running clock. If you want any specific details please send me a PM and I will try to help. |
