roy entwistle | 01/12/2021 10:10:37 |
1716 forum posts | Good morning folks. I have several pairs of CK box joint pliers. I am just wondering how they are made. There doesn't appear to be enough metal to expand the hole in one leg, then insert the other leg and then close the hole up particularly with end cutters Roy |
Clive Foster | 01/12/2021 10:26:05 |
3630 forum posts 128 photos | Roy Blacksmith technique is start by forging the hole the "correct" shape then heat it to red hot stretch it with a shaped chisel type tool push the other jaw through reheat to red forge the stretched eye back to shape make hole for pin Video of the blacksmith method here https://www.youtube.com/watch?v=vPoFdNgQn4s Industrial techniques will be basically the same but adapted to series production. I suspect the apparent lack of metal to expand the hole in you CK pliers is due to grinding down to size after the pliers have been made. The bit I really don't get is how they manage a precise fit in the hole with just enough clearance for operation but not so much that the jaw wobbles sideways. Clive
Michael Gilligan | 01/12/2021 10:31:11 |
![]() 23121 forum posts 1360 photos | Posted by roy entwistle on 01/12/2021 10:10:37:
[…] There doesn't appear to be enough metal to expand the hole in one leg, then insert the other leg and then close the hole up particularly with end cutters . … But of course there must be [because that’s how they are made] https://youtu.be/vPoFdNgQn4s MichaelG. . Clive beat me to it Edited By Michael Gilligan on 01/12/2021 10:32:02 |
Speedy Builder5 | 01/12/2021 11:41:35 |
2878 forum posts 248 photos | Another thing, why don't the two halves weld themselves together at white heat ? Mystery. |
roy entwistle | 01/12/2021 12:50:23 |
1716 forum posts | Thanks for your input gentlemen. They manage to get the joints nice and tight. Roy |
Michael Gilligan | 01/12/2021 15:03:07 |
![]() 23121 forum posts 1360 photos | I doubt if these were Blacksmith-made: .
… It would be interesting to see how they do it ! MichaelG. |
Tim Stevens | 01/12/2021 17:26:42 |
![]() 1779 forum posts 1 photos | The object of the box joint (just in case you were wondering) is to have a joint which can withstand twisting in both directions. Very useful for manipulating body parts and bending wires etc. With a conventional joint you can only twist one way without risking the joint pulling apart (and so, the blades not meeting properly). Very popular with making jewellers, as well as the Surgeons who like the whole tool to be a) polished) and b) stainless. Cheers, Tim |
Michael Gilligan | 01/12/2021 17:47:37 |
![]() 23121 forum posts 1360 photos | No, Tim … I wasn’t really wondering But thanks anyway MichaelG. |
ega | 01/12/2021 17:53:57 |
2805 forum posts 219 photos | For the benefit of posterity could the thread title please be amended? |
old mart | 01/12/2021 19:18:36 |
4655 forum posts 304 photos | The halves will not weld together because firstly the steel is only heated a dull red, and secondly because the joint is only closed enough to fit. |
Ian P | 01/12/2021 19:47:32 |
![]() 2747 forum posts 123 photos | Posted by Tim Stevens on 01/12/2021 17:26:42:
The object of the box joint (just in case you were wondering) is to have a joint which can withstand twisting in both directions. Very useful for manipulating body parts and bending wires etc. With a conventional joint you can only twist one way without risking the joint pulling apart (and so, the blades not meeting properly). Very popular with making jewellers, as well as the Surgeons who like the whole tool to be a) polished) and b) stainless. Cheers, Tim I imagine that surgeons instruments would need to be dismantled for sterilisation so unlikely to box jointed (in the blacksmith forged) manner. Ian P |
Michael Gilligan | 01/12/2021 20:06:17 |
![]() 23121 forum posts 1360 photos | Posted by Ian P on 01/12/2021 19:47:32: […] I imagine that surgeons instruments would need to be dismantled for sterilisation so unlikely to box jointed (in the blacksmith forged) manner. . Although the ones I photographed were purchased ‘non-sterile’ … I feel pretty sure that they are a surgical design: and as such, they would be sterilised in an autoclave. MichaelG. . Edit: __ That pair don’t have the locking mechanism; so technically they are not ‘Artery Forceps’ … but this should confirm my supposition: Edited By Michael Gilligan on 01/12/2021 20:15:46 |
Ian P | 01/12/2021 20:43:37 |
![]() 2747 forum posts 123 photos | I have a vague recollection that (about 8 or 10) years ago that a patient under surgery suffered because some jointed instrument had crevices that did not fully sterilise. One of my relatives sold medical equipment to theatres and I said I was sure I could design something that dismantled for cleaning but he assured me that I needn't trouble my little self as the products in use had separatable components. Ian P |
Robert B | 01/12/2021 21:30:48 |
20 forum posts 6 photos | Surgeons tools may now be destroyed as a prevention of BSE infections getting through. This happened to metal implements used for dressing a wound in an A&E visit. I don't know how though as the nurse didn't. |
Michael Gilligan | 01/12/2021 23:34:16 |
![]() 23121 forum posts 1360 photos | That’s interesting, Robert ‘though it appears to conflict with this: **LINK** https://www.nice.org.uk/guidance/IPG666/InformationForPublic [perhaps I am just tired] MichaelG. |
ega | 02/12/2021 10:23:08 |
2805 forum posts 219 photos | Moderator: Thank you for the end of the pier! |
roy entwistle | 02/12/2021 11:22:21 |
1716 forum posts | Apologies for the Pier instead of Plier. Put it down to old age. Roy |
