Marked "RE" and "A87"
AJAX | 29/11/2021 23:54:53 |
433 forum posts 42 photos | Although I've not yet had the need to use it, I realise that small sensitive drill presses are popular with some model makers. With that in mind, is anyone able to identify the make / model shown in the photos below? Apart from giving it a good clean and fresh coat of paint, it looks to be unmodified. Edited By AJAX on 29/11/2021 23:55:30 |
DiogenesII | 30/11/2021 07:05:42 |
859 forum posts 268 photos | Could it be a Reeves Bench Drill? AJReeves - Workshop Equipment Castings ..looks like a well-made tool.. |
Clive Foster | 30/11/2021 08:50:22 |
3630 forum posts 128 photos | Doesn't look like one made from a Reeves casting set. Similar concept but not the same. Different pulley arrangements. https://www.worthpoint.com/worthopedia/bench-drill-made-reeves-castings-168431048 Back in the day there were many makers of small, simple drill presses. That one looks to be one of the nicer versions. Clive |
Nicholas Farr | 30/11/2021 09:39:07 |
![]() 3988 forum posts 1799 photos | Hi here is a scan of the one that Clive has linked to and has the same drawing code to the one in DiogenesII's link. Regards Nick. Edited By Nicholas Farr on 30/11/2021 09:47:48 |
AJAX | 30/11/2021 18:43:44 |
433 forum posts 42 photos | Posted by DiogenesII on 30/11/2021 07:05:42:
Could it be a Reeves Bench Drill? AJReeves - Workshop Equipment Castings ..looks like a well-made tool.. After reading your suggestion I searched for Reeves bench drills and couldn't find anything that matched. Are they known to include "RE" in the castings? Brian |
AJAX | 30/11/2021 18:46:16 |
433 forum posts 42 photos | Posted by Clive Foster on 30/11/2021 08:50:22:
Doesn't look like one made from a Reeves casting set. Similar concept but not the same. Different pulley arrangements. https://www.worthpoint.com/worthopedia/bench-drill-made-reeves-castings-168431048 Back in the day there were many makers of small, simple drill presses. That one looks to be one of the nicer versions. Clive Thanks, I agree that it does seem nice. Although I have no use for it at present maybe I'll find a use for it one day. |
AJAX | 30/11/2021 18:49:27 |
433 forum posts 42 photos | Posted by Nicholas Farr on 30/11/2021 09:39:07:
Hi here is a scan of the one that Clive has linked to and has the same drawing code to the one in DiogenesII's link. Regards Nick. Edited By Nicholas Farr on 30/11/2021 09:47:48 Thanks Nick. Some similarity, but mine features a rack and pinion quill feed. In some ways it's almost a larger bench drill in a miniaturized form. |
Greensands | 01/12/2021 12:02:05 |
449 forum posts 72 photos | Have attached some pics of my vintage sensitive drill press which was picked up at a carboot sale some years ago and has proved to be a very useful addition to the workshop. As in the OM, I have no idea of its origins and have never been able to decipher the makers name from the initials cast into the base. Any suggestions would be most welcomed.
AJAX | 01/12/2021 12:35:37 |
433 forum posts 42 photos | Posted by Greensands on 01/12/2021 12:02:05:
A quick Google search found HKS as makers of machine tools. |
Greensands | 01/12/2021 12:43:46 |
449 forum posts 72 photos | Thanks for that, very useful bit of info. I must confess however that I have never been able to read HKS into the cast panel. You live and learn on this forum. |
Nigel Graham 2 | 01/12/2021 13:21:29 |
3293 forum posts 112 photos | HKS... or SHK? I have just perused lathes.co, looking for names that might match the initials, not just on drilling-machines, without luck! |
