Leon Vorster | 05/11/2021 18:16:06 |
4 forum posts | Hi Everyone, I've checked the forum and googled a abit and I am a little stumped. How does one remove the tufnol gears (HeadStock Assembly: Part 35, 46) ? Any help would be greatly appreciated. |
Tony Pratt 1 | 05/11/2021 18:23:34 |
2319 forum posts 13 photos | Looks like the gear stud [35] is a press fit in the tumbler reverse lever [55] Tony |
Leon Vorster | 05/11/2021 18:25:11 |
4 forum posts | Okay I did find some related posts after all. So it seems I need to remove the entire Tumbler Reverse Lever by removing the grears then removing the Tumbler Reverse Locating Screw and then I take it I would need to apply some force to the rear of the studs to pop them out .... does that sound about right ? Edited By Leon Vorster on 05/11/2021 18:25:46 |
KWIL | 05/11/2021 19:06:51 |
3681 forum posts 70 photos | You can remove the entire cluster, first remove the locating screw and then it just pulls away with the gears still on. Indedd the studs are a press fit. |
Leon Vorster | 09/11/2021 08:36:23 |
4 forum posts | Posted by KWIL on 05/11/2021 19:06:51:
You can remove the entire cluster, first remove the locating screw and then it just pulls away with the gears still on. Indedd the studs are a press fit. Thanks KWIL I managed to get them out. |
